Recording Stopped due to Dropped Frames during Log and Capture
Jonathan Reed
on Jun 8, 2015 at 11:10:15 pm
I was doing a log and capture when a warning came up of "Dropped frames" and fcp ended my capture... I also can't find the video. Isn't that already saved? did I lose it forever?
JR
David Roth Weiss
Re: Recording Stopped due to Dropped Frames during Log and Capture
on Jun 8, 2015 at 11:30:37 pm
Tough to tell exactly what happened or where the files are without a lot more info... However, it certainly sounds as if you inadvertently directed the capture to your boot drive, which is probably not fast enough to capture without dropping frames.
You can search the boot drive using Spotlight, filtering by file extension, date, etc., however, they most likely won't be useable due to dropped frames.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions
David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
