MXF in FCP7
Dorothy Dickie
MXF in FCP7
on Jun 5, 2015 at 9:58:13 pm
I shot footage on my Canon XF305 and when I log and transfer the MXF files into FCP7 , I am seeing what looks like drop outs all over the media. I am wondering if it's a corrupted CF card or a file directory issue when I import into FCP. I copied the files to my hard drive and reused the cards so I am unsure the exact source of the problem. This has happened on two out of seven shoots with these cards so I doubt that's it's a card issue. But I'm not sure. Has anyone run into this problem and discovered the source? What have I done wrong?
Shane Ross
Re: MXF in FCP7
on Jun 7, 2015 at 6:14:42 pm
Try a third party converter...a demo of it...to see if the cards still exhibit this behavior. I recommend EditReady by Divergentmedia.com. If the glitches are still there...then it might be a recording issue. If not...it's that FCP 7 is old old old...and was actually discontinued before the 305 came out, so it might not be able to handle that format properly.
Shane
Little Frog Post
