Synced audio becomes massively unsynced in Final Cut Pro 7 when pasting
Ortho Stice
on Jun 2, 2015 at 2:41:58 am
Hey guys!
So I used Plural Eyes to sync up my video from Canon 60d with my external audio (recorded on a zoom h5) and it worked great. It put a synced sequence of all the footage together and exported it to Final Cut Pro 7 no problem. But now, if I try to move the footage from the timeline in any way, either to the project file list or to the timeline of another project (I created a new project to make editing easier), it becomes MASSIVELY unsynced, i.e., the sound doesn't even resemble where it's supposed to be. Any idea what's causing this problem? Thanks!
Dave LaRonde
Re: Synced audio becomes massively unsynced in Final Cut Pro 7 when pasting
on Jun 2, 2015 at 5:20:42 pm
What is the codec of the footage? Ideally, it should be ProRes 422 for FCP. If it's H.264, there's your problem. The fix: transcode the video to ProRes 422 and try again.
It wouldn't hurt to double-check the audio, either: FCP wants aiff or wav, 48kHz, 16 bits, either stereo or mono.
Dave LaRonde
Promotion Producer
Nick Meyers
on Jun 2, 2015 at 11:39:06 pm
also check that the sequence you are pasting to has the correct settings
(same as clips and synced sequence)
nick
