WAVS slipping out of sync when imported to FCP
Ceri Allen
on May 29, 2015 at 3:50:51 pm
Hi
I am working in FCP 7.0.3 on a timeline apple pro res 422 (HQ) 1920x1080, 25fps, 48 kHz 24-bit.
I created audio wavs from this timeline via the export as quicktime conversion option (kept the default settings.)
When I drop the wavs back into FCP and lay them on the same timeline, they drift out of sync.
I understand that FCP defaults to NTSC presets but I have my sequence preset set to apple pro res 422 1920x1080 25p 48KHz.
Also when I check the spec of the wavs in quicktime they are 48KHz and 24-bit so they match up with the timeline settings I am dropping them onto.
I would like to discover if there is a problem with the wavs themselves or if the problem is with how FCP is re-importing them (as it went to broadcasters so I need to know if the wavs themselves need fixing) . Any help on this would be great.
thanks
Ceri
