854 X 480 sequence
Greg Ball
854 X 480 sequence
on May 28, 2015 at 5:28:30 pm
Here's a dumb question. I ripped video footage from a DVD I created. ( i no longer have the raw footage.
Using MPEG StreamClip I saved it as a 854 X 480 pro res clip. Although it drag fine in my new sequence, it does not play.
Any thoughts? Do I need to same it as 720 X 480 then make the settings anamorphic?
Shane Ross
Re: 854 X 480 sequence
on May 28, 2015 at 6:32:20 pm
FCP works best with standard video formats...the dimensions you ripped aren't standard. So yes, it's best to convert that to 720x480 Anamorphic, and use a sequence with the same settings.
FYI, Adobe Premiere isn't so finicky...it'll take that clip no problem.
Shane
Little Frog Post
