Error: Out of Memory
Gerret Warner
on May 23, 2015 at 11:37:38 am
Every time I try to render I get this memory message. Crazy. Has never happened before. I've got 16GB of memory and no other apps are open. Naturally, I'm fighting a tight deadline.
I've quite/re-opened; shut down/restarted but no luck.
Thanks in advance for any suggestions.
Shane Ross
Re: Error: Out of Memory
on May 23, 2015 at 11:13:34 pm
Do you have any stills in your sequence? Are they over 4000 pixels on any side? FCP can't deal with images over 4000 pixels.
Do you have any H.264 or MP4 or any other non-FCP compliant codec on the timeline? What is the codec of the footage you are cutting? What are your sequence settings?
Shane
Little Frog Post
