dropping frames
Tom Fino
dropping frames
on May 12, 2015 at 1:37:58 pm
I rotated a clip 180 degrees using the Motion function in FCP 7 and now it's dropping frames. The original clip is playing normally.
Any advice? Thanks.
Shane Ross
Re: dropping frames
on May 12, 2015 at 2:07:54 pm
Did you render it?
Shane
Little Frog Post
Tom Fino
Re: dropping frames
on May 12, 2015 at 2:49:36 pm
Yes, it's rendered.
Shane Ross
Re: dropping frames
on May 12, 2015 at 2:55:23 pm
What is the codec of the footage? What are the sequence settings? What drive is this stored on?
Shane
Little Frog Post
Tom Fino
Re: dropping frames
on May 12, 2015 at 3:19:38 pm
Thanks, it seems to be working now.
I have another problem maybe you can help with.
I'm using footage that was shot with a Sony A7-S at 24fps. I converted it to QuickTime H.264 files. Files are on an external hard rive.
On the timeline, whenever the player head approaches the end of one clip and the beginning of another, the image in the outgoing clip hesitates or stutters just before the transition to the next clip.
I'd appreciate any help you could give. Thanks.
Shane Ross
Re: dropping frames
on May 12, 2015 at 5:19:49 pm
Dave answered that for you in your other post
Shane
Little Frog Post
