Beta transfer & digital capture
Jim Hoey
on May 7, 2015 at 6:08:27 pm
Hi everyone,
I have old beta SP tapes I would like for capture from Betacam SP unconverted to HD Apple ProRes. How do I undertake this workflow?
J
Dave LaRonde
Re: Beta transfer & digital capture
on May 7, 2015 at 6:21:42 pm
Got a deck and a capture card? You'll need both, or you'll need someone else to do it. The capture will be in SD, and it will be up to you to do the upscaling.
Dave LaRonde
Promotion Producer
Shane Ross
on May 7, 2015 at 6:22:31 pm
Best capture card for this is the AJA Kona 3G. I do this all the time with beta SP and digibeta, for docs now shot in HD.
Shane
Little Frog Post
Jim Hoey
on May 7, 2015 at 6:26:55 pm
Will FCP 7 work Shane?
Dave LaRonde
on May 7, 2015 at 6:45:41 pm
Sure... as long as you have a capture card installed. FCP7 all by itself can't do it.
Dave LaRonde
Promotion Producer
Shane Ross
on May 7, 2015 at 7:12:01 pm
Well, yes. The Kona 3G was designed for use with FCP 7. I did this all the time with FCP 6 and 7.
Shane
Little Frog Post
Shane Ross
on May 7, 2015 at 7:13:13 pm
Wrote and article on it in fact...here on the Cow...
https://library.creativecow.net/ross_shane/aja_kona3/1
Shane
Little Frog Post
