Quicktimes I'm exporting are dual mono- need stereo
Lisa Olshanski
on May 6, 2015 at 10:29:48 pm
Okay. I've read the manual and I believe everything I can set to Stereo is set to stereo (see screen grabs below) but my Quicktimes that I export from FCP with current settings are coming out dual mono. Why? And how can I get them to come out with a Stereo mix without having to do QT conversion or go through compressor? My only audio tracks is a stereo mix directly from the audio engineer. Thanks in advance for any help!
MacBook Pro- Mac OS ver. 10.9.3- Processor 2.3GHz- 16GB memory
Final Cut 7
Adobe Premiere CC
Michael Gissing
Re: Quicktimes I'm exporting are dual mono- need stereo
on May 6, 2015 at 11:44:57 pm
Did you check the panning in the timeline?
Lisa Olshanski
on May 6, 2015 at 11:48:09 pm
When i double click on the clip it is says -1 in the source window. That's correct right?
Final Cut 7
Adobe Premiere CC
Shane Ross
on May 7, 2015 at 12:05:43 am
Everything says stereo...even the Quicktime information...so why do you think it's dual mono?
Shane
Little Frog Post
Lisa Olshanski
on May 7, 2015 at 1:03:06 am
Because the place that's trafficking the spots told me. They asked me to fix them.
Final Cut 7
Adobe Premiere CC
Massimo Alberto Croce
on May 7, 2015 at 12:05:35 pm
Two thing, first of all, you need to discover if the file from sound engineer is a real steep or dual mono (use a correlation meter to discover it). Second, if the file is real stereo, you need to pan pot ch1 to left and ch2 to right.
Video Editor, Colorist, Pro Tools Editor
massimoalberto.croce@gmail.com
Shane Ross
on May 7, 2015 at 1:55:15 pm
If they say it's dual mono, then the files you got back from the audio engineer might be dual mono. Yeah, you'll have to have that checked.
Shane
Little Frog Post
