can't set up in and out points while importing
Lucy Slavinsky
on Apr 26, 2015 at 11:18:23 pm
Hello all,
For some reason I am not able to set up in ana out points while importing. All I am able to do just select and import entire clip, which is unbelievably annoying. I am trying to import QuickTime movie. WhAt am I doing wrong?
Thank you in advance.
Shane Ross
Re: can't set up in and out points while importing
on Apr 27, 2015 at 1:08:30 am
Importing simply makes a clip that points to the media as it exists...it doesn't make new media, or convert anything. It just makes a pointer to the media.
You can set IN and OUT points if you Log and Capture from tape, or if you Log and Transfer from tapeless media cards.
Shane
Little Frog Post
Lucy Slavinsky
on Apr 27, 2015 at 1:20:00 am
I should, but I can't. When I press I all I can get is a squeaky sound and the entire clip gets selected.
Shane Ross
on Apr 27, 2015 at 3:10:53 am
What is this footage? Where does it come from?
Shane
Little Frog Post
Lucy Slavinsky
on Apr 27, 2015 at 5:03:02 am
Some from the camera man, he copied it to my hard drive, some I converted from Mp4 to apple prores
Shane Ross
on Apr 27, 2015 at 5:15:32 am
Which camera? If you want to get IN and OUT points, you first need to have the whole card structure intact. Second, you need the specific Log and Transfer plugin for that camera type. Then L&T will work. If the camera is very new (made within the past 4 years), there might not be support for that camera type. In which case you need to convert the footage with a third party converter. And then the resulting file you import fully...no way to do IN and OUT Points.
Shane
Little Frog Post
Lucy Slavinsky
on Apr 27, 2015 at 5:22:40 am
Unfortunatly its too late. The footage I got was copied from the card to my external hard drive. All clips are .mov files
Shane Ross
on Apr 27, 2015 at 5:38:43 am
MOV in what codec? MOV means Quicktime..but are they MPEG 4, H.264, ProRes? FCP only works with ProRes...or other FCP codecs. So you need to convert the footage to that format. And sorry, if they are MOV files, you cannot make IN and OUT points in FCP when importing, and only import the portions you want. Not even sure the third party converters offer that option. So you might be stuck with the full clips.
Sorry
Shane
Little Frog Post
Lucy Slavinsky
on Apr 27, 2015 at 12:10:15 pm
Apple Pro Res 422.
Shane Ross
on Apr 27, 2015 at 4:11:10 pm
Good codec. Just no IN and OUT points when importing.
Shane
Little Frog Post
Lucy Slavinsky
on Apr 27, 2015 at 4:14:27 pm
Bummer! Thank you very much for your help
