FCP 7 crashing when even touching Motion templates
Warwick Meade
on Apr 17, 2015 at 4:09:17 am
I have a copy of FCP 7 on OS X Yosemite.
Its has been working sweetly for 4 months now, including using Motion Templates for subtitles, lower thirds etc.
Yesterday I loaded a trail versions on FCP X so I can get to grips with it.
Now even when I touch the subtitles in FCP 7 it crashes. i can barely touch a timeline with a motion template on it.
any thoughts? Its driving me nuts!
Many thanks in advance!
w
Shane Ross
Re: FCP 7 crashing when even touching Motion templates
on Apr 17, 2015 at 4:41:10 pm
Well it's obvious. It worked...then you installed FCX...then it didn't work. FCX is interfering with it.
In order to have both FCX and FCP 7 (studio 3) on the same computer, you need to follow some specific steps:
https://support.apple.com/en-us/HT202240
Shane
Little Frog Post
Warwick Meade
on Apr 17, 2015 at 8:27:32 pm
too true, unfortunately all the instructions include firing up Motion 4, which i can't do, because motion 4 does not work on OS X.
am hoping there are prefs i can change or folder structure I can change mutually.
Hoping to not have to uninstall FCP X, but looking like I may have to.
w
Mark Suszko
on Apr 17, 2015 at 9:29:19 pm
IMBW, but I think an Yosemite OS install breaks Motion 4 and leaves you only able to use motion 5, unless you set up dual boot partitions first. Or am I thinking of Compressor?
