How do I get my plugin metadata from workstation to workstation?
Mark Kepko
on Apr 17, 2015 at 3:50:11 am
When I'm transferring my xml between workstation my plugin parameters get reset. The plugins I'm using on this particular project are alex4d, sc_animated masks and crunclepop screen splitter.
Is there a way to export xml that contains the parameters for plugins?
Nick Meyers
Re: How do I get my plugin metadata from workstation to workstation?
on Apr 17, 2015 at 9:11:09 pm
that should be working as a matter of course.
the XML should carry the filter settings.
maybe trash prefs on both systems and try again.
do you have to use XML?
can you not just move the project file?
nick
