How do you choose the correct sequence settings?
Caroline Scott
on Apr 6, 2015 at 2:06:33 pm
Hi there,
I am having to render a lot of my footage, which I believe may be unnecessary because of my sequence settings. I have 'log and transferred' my footage in to Final Cut Pro 7 and in the browser it says my clips are ProRess 422.
What should my sequence settings be set to?
I initially had it on 'easy setup' and dragged the footage in to the timeline, to which I clicked 'yes' when asked to match the sequence settings. Thought this would automatically pick the right sequence settings for me but I guess not because of the rendering time...!
Expertise would be much appreciated, thank you.
Caroline
Caroline Scott
Re: How do you choose the correct sequence settings?
on Apr 6, 2015 at 2:13:13 pm
this is a screen shot of my browser settings
Massimo Alberto Croce
on Apr 6, 2015 at 4:31:44 pm
the sequence setting should be the same of the footage, for best real time performance.
Video Editor, Colorist, Pro Tools Editor
massimoalberto.croce@gmail.com
Dave LaRonde
on Apr 6, 2015 at 4:49:41 pm
Open a new sequence. Put in one of the clips in question.
FCP should then ask, "Do you want to change the sequence settings to match this clip?" or words like that.
Say yes. Then scrutinize those sequence settings. If they are NOT what you intended, there was a mistake made at Log & Transfer time.
Dave LaRonde
Promotion Producer
Shane Ross
on Apr 6, 2015 at 6:06:42 pm
Those are you BIN settings, and they don't show us what is what? What is a clip? What is a sequence? Click on your sequence and go to the SEQUENCE menu and choose SETTINGS. Show us that.
Shane
Little Frog Post
