Outputting DCPro HD QT file with 4 channels for PBS
Nel Shelby
on Mar 27, 2015 at 2:41:34 pm
I am trying to output a DVCPro HD QT file for PBS specs. They requested Channel 1 and 2 stereo and Channel 3 and 4 mono. My composer gave me those files and they are set in my timeline. Now I am trying to export in compressor or quick time conversions so that the 4 channels will stay in tact and not mix down to stereo?
Here are the audio specs:
[AUDIO]
48K Sample Rate
24bit or 16 bit
Loudness: -24 LKFS +2/-2 db (peak up to -6db)
Ch1 & Ch2: Stereo Full Mix
Ch3 & Ch4: Mono Mix
Thanks for your help.
Nel
Dave LaRonde
Re: Outputting DCPro HD QT file with 4 channels for PBS
on Mar 27, 2015 at 3:31:24 pm
PBS is notorious for having really tough technical delivery specs... and audio may be the least of your worries. They're very picky.
I'd try to find someone nearby who's done such work for them... and hire that person to help out. In the long run, it may be a LOT cheaper; you wouldn't have to keep doing the project over & over because PBS keeps rejecting it for one tech spec or another.
Dave LaRonde
Promotion Producer
Shane Ross
on Mar 27, 2015 at 4:03:50 pm
Here's a tutorial on how to do that:
http://library.creativecow.net/ross_shane/multi-audio/1
This exports a Quicktime movie, NO conversion, out of FCP. Is your sequence DVCPRO HD? Or some other codec? If another codec, you might need to export a QT, convert that to DVCPRO HD, bring that back into FCP, put it on a DVCPRO HD timeline, they add the audio to that sequence, then do the above tutorial.
Shane
Little Frog Post
