Unlinked audio (muti) tracks, how to link them together again.
Karel Voners
on Mar 25, 2015 at 4:06:03 pm
Don't know how to describe this issue but I'll do my best.
I have an audio file containing 4-6 tracks from different microphones.
When I insert them on the timeline all of them are linked, when I "go to the frame" on the audio clip it show the file with all the tracks in the viewer.
Now for some reason, some of the audio has become "unlinked". When I select the clip is only selects the clip of one track, only that single audio track gets highlighted, and when I go to the frame it only opens that audio channel in the viewer. (no other audio channels appear in different tabs in the viewer).
Does anyone know how to solve this?
K
Nick Meyers
Re: Unlinked audio (muti) tracks, how to link them together again.
on Mar 27, 2015 at 2:57:01 am
2 ways clips can behave as you describe:
1. they have become un-linked
2. you have Linked Selection turned off in the timeline
a bit hard to tell from your pic which it is, as your timeline view of "reduced" leaves out the link indicator, which is a fine line under the clip name.
tuning linked selection on (or off!) is very easy: Shift L
or the tiny link button top right of the timeline.
it's also relatively easy to unlink all your clips.
select everything in the timeline, and hit Command L
but to re-link, you can only do it ONE CLIP AT A TIME.
select the tracks (including video, if any) and Command L
nick
