Best way to convert footage from 60i to 24fps?
Vanessa Lee
on Mar 12, 2015 at 2:32:51 am
I am trying to get a film/cinema look from footage taken by an older HDV 1080 60i pro camera using FCP or compressor (or perhaps another program)?
What is the best approach to doing that? is it better done in FCP or Compressor? or somethere else?
Shane Ross
Re: Best way to convert footage from 60i to 24fps?
on Mar 12, 2015 at 3:54:20 pm
The BEST way is with a hardware converter called a Terranex. Route the camera through that and capture. BlackMagic design makes them cheaper now, but still not cheap enough for many to buy. But many post houses have them in use.
Second Best....After Effects.
Third Best...something more at your disposal...Compressor. But you'll have to turn all the frame controls to BEST and then wait for a long time as it does this process. Unless footage is shot with 24p in mind (Cameras that shoot 24p Advanced, or some form of 24p), it will need some processing in order to make it look decent.
Shane
Little Frog Post
Dave LaRonde
on Mar 12, 2015 at 4:35:54 pm
There's also a third-party plugin from Re:vision efx called Twixtor that does frame rate conversions. It's pricey, it involves a bit of a learning curve to use effectively, but it yields good results.
Dave LaRonde
Promotion Producer
