Best Sequence Settings for Editing & Playback of DSLR Footage?
Thomas Hughes
on Mar 11, 2015 at 10:34:45 pm
When shooting video with a DSLR and cutting in FC7, what are the sequence settings you’re using? Historically we use XDCAM for our sequence settings (1080i, 8 bit, 29.97). The reason we use that setting is that we’ve tried all sorts of other sequence settings and we always have playback issues. But we’re convinced our picture quality is not as good as it should be, so we’re trying to find the weak link in the chain and wonder if it’s a mistake for us to use XDCAM for our sequence settings. Any suggestions? Thank you.
Thomas H
Shane Ross
Re: Best Sequence Settings for Editing & Playback of DSLR Footage?
on Mar 11, 2015 at 11:08:35 pm
XDCAM should only be used for XDCAM footage. It's a Long GOP format, and any non-GOP format it that will be wonky.
Use a ProRes 422 sequence setting, and convert all your footage to ProRes BEFORE you import it and begin editing. Never bring in the native H.264 files. FCP does not work well with them.
Shane
Little Frog Post
Thomas Hughes
on Mar 11, 2015 at 11:18:48 pm
Thank you Shane. What specific apple 422 compression do you compress at? tx
Thomas H
Shane Ross
on Mar 11, 2015 at 11:20:38 pm
There is only one 422 settings...ProRes 422. There's also ProRes LT, ProRes HQ...and ProRes Proxy and ProREs 444 if you have FCP 7. Zero is gained in choosing ProRes HQ over ProRes 422 for DSLR footage...other than 50% larger file sizes, so I just use ProREs 422
Shane
Little Frog Post
Thomas Hughes
on Mar 11, 2015 at 11:21:06 pm
Also after compressing the footage in apple prores 422, what is the best apple prores sequence setting? Thank you.
Thomas H
Shane Ross
on Mar 11, 2015 at 11:22:34 pm
Your clip settings and sequence settings must match. So if you convert the footage to ProREs 422...use a ProRes 422 sequence. Just make a new sequence, add a clip, and click YES when FCP asks to make the sequence match. Done.
Shane
Little Frog Post
Thomas Hughes
on Mar 11, 2015 at 11:30:24 pm
Thank you
Thomas H
