What is XDCAM HD Generic?
Haider Jafree
on Mar 9, 2015 at 4:51:54 pm
I am using FCP 7 and I want to export MXF containing XDCAM HD 422 codec, but when i export mxf it gives me two options for compression:
1- XDCAM HD
2-XDCAM HD Generic
which one should i use if i want "XDCAMHD 422"
Shane Ross
Re: What is XDCAM HD Generic?
on Mar 9, 2015 at 6:15:15 pm
How are you exporting? Are you using the FILE>EXPORT>XDCAM from FCP?
Shane
Little Frog Post
Haider Jafree
on Mar 9, 2015 at 7:23:34 pm
No, I am exporting as follows:
FILE>EXPORT>MXF in FCP
Shane Ross
on Mar 9, 2015 at 11:42:20 pm
I'm sorry, I don't see that option. Are you sure you are using FCP 7...and this isn't FCP-X?
Shane
Little Frog Post
Haider Jafree
on Apr 9, 2015 at 2:39:27 pm
Sorry for late reply.
I am using a third party plugin to export xdcam. I found that XDCAM HD Generic is actually XDCAM HD 422. So my problem was resolved
