Converting 1080i60 to ProRes422 (HQ) for PAL Delivery - Audio Issues
Michael Schmidt
on Feb 26, 2015 at 4:31:54 pm
Hi all,
We need to deliver 26 episodes of a US show to the Middle East. I've been able to get the video converted well using Compressor or AME but I'm having a terrible time getting the audio specs correct. They are requesting two stereo tracks (Full Mix/M&E) embedded at 24bit/48k Big Endian. I can get FCP7 to export with the audio tracks embedded but it they always end up at 16 bit/48 little endian. Using Compressor OR AME just seems to always merge the two stereo tracks together. Any advice on how I can accomplish?
EDITING SPECS
DVCPRO HD 1080i60, 29.97, 16bit/48k
DELIVERY SPECS
Video: QuickTime Movie (*.mov)
Compression: Apple ProRes 422 (HQ)
Quality: Best
Frame rate: 25 fps
Scan Mode: Interlaced
Aspect Ratio: 16:9 1.78
Dimensions: 1920 x 1080
Field Dominance: Upper Field First
Sound:
Format Integer (Big Endian)
Sample rate: 48.000kHz
Sample size: 24-bit
Channels: 1/2ch Stereo MIX
3/4ch Stereo M&E
Shane Ross
Re: Converting 1080i60 to ProRes422 (HQ) for PAL Delivery - Audio Issues
on Feb 26, 2015 at 4:38:29 pm
Go into the Sequence Settings, and in the lower right of the GENERAL Tab, change the depth from 16 bit to 24bit, and the Config to Discreet.
Shane
Little Frog Post
