1280x544 and 1280x720
Bobby Hall
on Feb 21, 2015 at 4:50:18 am
I have an .mp4 file I want to edit in FCP7 that's a rip of a movie and the format is h.264 and 1280x544. In MPEG Streamclip I converted it to prores and chose 1280x720. Is this correct or should I have chosen 1280x544? Is there any reason not to choose the original format?
I also did a test and converted a portion of the 1280x544 movie to 1280x720 because I wanted to see how different it would look but it's identical to the original. If I convert the 1280x544 video to 1280x720 why isn't the aspect ratio different? Shouldn't it be stretched vertically? 1280x544 has an aspect ratio of 2.35:1 and 1280x720 is 1.78:1 so why does it look the same?
Shane Ross
Re: 1280x544 and 1280x720
on Feb 21, 2015 at 4:21:16 pm
I can't tell you why it doesn't look different, but I can tell you that FCP only works with 1280x720 (or 960x720 anamorphic)...so you need to keep it that aspect ratio if you are going to work with FCP. And you need to convert it to ProRes....FCP doesn't work with MP4 well. Tons of potential issues.
Shane
Little Frog Post
Nick Meyers
on Feb 23, 2015 at 8:31:45 am
next to impossible to tell without seeing your original and the convert.
BUT
- could be a pixel ratio issue. you can bring that mp4 into FCP just to look at it;s format details if you want
- has MPEG Streamclip padded the video in some way? (added black bard top& bottom)
i didn't know it could do that if it did.
i use Compressor for converting odd formats to FCP friendly video, partly for the padding options
nick
