FCP 7 and Maverick - which external hard drive to use?
Sylvie Bolioli
on Jan 29, 2015 at 4:16:15 pm
Hello, I'm still using FCP7. When I upgraded to Lion and Maverick, a G-Raid drive containing my whole movie edit was corrupted. I have tried to install a Snow Leopard partition but I cannot use the drive any longer, not even on Snow Leopard. Hopefully I can still copy the files over to a new drive. Is there a different better brand of External Drives I should use?
Thank you,
Sylvie
David Roth Weiss
Re: FCP 7 and Maverick - which external hard drive to use?
on Jan 29, 2015 at 5:04:55 pm
Before you do anything else you should purchase Disk Warrior and run it on your drive. It will be the best $99 you ever spent, and if the drive is corrupted and your issue is not a hardware failure DW will most likely repair it.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions
David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
Sylvie Bolioli
on Jan 29, 2015 at 5:06:48 pm
Thank you very much David, I will try that
