I am getting low quality DVD files
Jai Gopal
on Jan 27, 2015 at 10:31:55 am
I have a problem with exported DVD file quality. This problem is not only with one project. I use FCP 7 and export mov file with the same setting as timeline footage and then convert into compressor but somehow I am getting very low quality DVD files. I have already checked the bit rate and the other settings.
This problem only started when I formatted my HDD and reinstalled the software. I also tried Toast 11 and Compressor 4.1 which are also giving me the same quality.
It seems like the mov file is making a problem but it's a high quality video file when I play. I also use ProRess 422 HQ file which is also giving me the same quality for DVD.
Please help me.
Mark Suszko
Re: I am getting low quality DVD files
on Jan 27, 2015 at 3:35:15 pm
What happens to quality if you burn a DVD using the "share>DVD" path?
Dave LaRonde
on Jan 27, 2015 at 6:06:11 pm
I would also double-check the codec for the FCP edit timeline. If it's not at least ProRes 422 -- a fine codec, without the excessive, rarely-needed file size of ProRes HQ -- your image quality will suffer. A simple export of an FCP edit timeline is in the codec of the timeline; a bad codec means bad quality.
Dave LaRonde
Promotion Producer
