FCP 7 crashes exporting an XML
joel matthew
on Jan 22, 2015 at 4:07:46 am
I'm trying to export an XML of a large project so that I can use FCP7toX and get the project on my iMac with FCPX. Unfortunately, it crashes before finishing the XML. The error message is "The processing of the FCP XML has failed"
Any suggestions what to do to get an XML out?
I'm running FCP 7 on 10.6.8 Mac Pro 3,1 , Quad-Core Intel Xeon , 3.2 Ghz processor speed , 2 processors / 8 cores , RAM = 16 GB , Graphics NVIDIA GeForce 8800GT
Shane Ross
Re: FCP 7 crashes exporting an XML
on Jan 22, 2015 at 4:25:51 pm
What type of footage are you working with? Wondering if some non-FCP codec might be tripping it up. It doesn't say why it failed, huh?
Shane
Little Frog Post
joel matthew
on Jan 22, 2015 at 4:45:27 pm
Thanks for your question..... The project has a variety of sources for the footage, but all of it was imported into the project properly and still works in FCP 7.
No, no error message details. I don't know if there's a log anywhere I can check in FCP?
Shane Ross
on Jan 22, 2015 at 5:04:01 pm
So all the footage has been converted to FCP editing codecs? ProRes, DV/NTSC, DVCPRO HD...etc? Or is there anything that's H.264, or Photo JPEG?
Hmmm...what is the purpose of the XML? You can see if you can launch FCP without the media drive turned on, and export the XML with the media offline.
Shane
Little Frog Post
joel matthew
on Jan 22, 2015 at 8:50:04 pm
I'm able to start the XML export but it crashes even without the media drive attached.
Then it's spinning wheel, so I can't look into the Log.
Bummer, huh?
Shane Ross
on Jan 22, 2015 at 9:56:38 pm
Trash the FCP preferences. PREFERENCE MANAGER does this, and it's free. Apple uses it.
digitalrebellion.com
Shane
Little Frog Post
joel matthew
on Jan 22, 2015 at 10:27:58 pm
Okay, I trashed the preferences, but it crashed again. Shoot.
Any other suggestions?
I'd really like to use FCP 7toX, but if I can't get an XML of this old project, it will remain on the old Mac Pro forever. bummer.
Robert Withers
on Jan 23, 2015 at 3:35:46 am
I had some issues using XML to transfer a timeline from FCP7 to Premiere CC.
Major failure after a certain point in the timeline.
What I had to do was export the second half of the timeline in a separate file to get it to import in Premiere.
This was a 40 minute timeline.
Try doing segments of your FCP7 timeline. Good luck.
Robert Withers
Independent/personal/avant-garde cinema, New York City
Andreas Kiel
on Jan 23, 2015 at 9:47:50 am
I also would recommend to export the XML as portions.
- Andreas
Spherico
http://www.spherico.com/filmtools
"He who fights with monsters should be careful lest he thereby
become a monster. And if thou gaze long into an abyss, the abyss will
also gaze into thee." - Friedrich Nietzsche, Beyond Good and Evil
