FCP 7 Show Duplicate Frame isn't working (!)
shi pins
on Jan 20, 2015 at 11:56:17 am
HI All,
I'm editing a long form doc with hours of footage so being able to see dupe frames is crucial.
I had set it in the User Preferences and in the sequence settings, tried with a fresh sequence, tried renaming the clips but no joy...
Any ideas..? (working on OS 10.9.5,footage was shot on Cannon C100 with Ninja blade as an external recorder. Apple ProRess 422 dragged and dropped into a project)
Many thanks in advance for your help !
Shi
Shane Ross
Re: FCP 7 Show Duplicate Frame isn't working (!)
on Jan 20, 2015 at 5:23:38 pm
Make sure the footage has REEL NUMBERS. Without those, FCP doesn't know it's from the same clip. Reel number and timecode are the main things for Duplicate Frames to be displayed. I know many external recorders that record directly to QT don't add reel number in the metadata.
Shane
Little Frog Post
shi pins
on Jan 21, 2015 at 7:52:10 am
Thank you so so much Shane!
Of course it works :) Not sure why I haven't thought about it myself...
Thanks for putting me out of a two days misery :)
Shi
Zahoor Qadir
on Mar 28, 2019 at 12:06:43 pm
Hello All
Can anybody help me ...my fcp7 doesn’t show duplicate frames We shot with Alexa Mini and then transcoded footage in 422 apple prores LT format and has reel names and time codes in footage but still doesn’t highlited duplicate frames in FCP 7...pls help
Shane Ross
on Mar 28, 2019 at 8:38:38 pm
What OS are you running?
Shane
Little Frog Post
Zahoor Qadir
on Mar 29, 2019 at 3:59:07 am
Dear Shane,
Thanks for the revert currently I'm using OS x el Capitan version is 10.11.3 .
Shane Ross
on Mar 29, 2019 at 6:01:30 pm
The only think I can think of is the OS version. The last version of the Operating System that FULLY supported FCP 7 (FCS 3) is 10.6.8. Every update past that means going further and further from full support, and possibly features not working. by 10.9.5, Compressor and Motion, bundled in FCS 3...stopped working. Color was highly unstable. By 10.10, Color stopped working, and DVD studio pro as well. 10.11...I'm sure many features might be affected.
You can try to trash the FCP PReferences (look for PREFERENCE MANAGER by DIgital Rebellion...it's free) and see if that fixes it. If not...might be an OS support issue.
Shane
Little Frog Post
Zahoor Qadir
on Mar 30, 2019 at 12:49:56 am
Thank you so much shane for this information:)
