Moving clip, not playhead
Pat Trimmer
on Dec 31, 2014 at 8:04:52 pm
Is there a way to move the video clip frame by frame without moving the playhead?
Pat
Shane Ross
Re: Moving clip, not playhead
on Dec 31, 2014 at 10:03:38 pm
Yes...click on the clip and hold OPT, then use the arrows to move it back and forth. If it's between other clips...this won't work, you'll get a clip collision alert. If you want to SLIP the clip, so that the start and end points of it change, but it stays still, then you use the < and > keys for that.
Shane
Little Frog Post
Pat Trimmer
on Jan 1, 2015 at 6:11:18 am
Thank you!
