just received footage i need to edit into another music video - do i need to transcode this for FCP7?
raju bhai
on Dec 26, 2014 at 1:54:24 am
the specs are:
DV 720x576 (768x576 actual), millions
16-integer
25 fps
This footage came from India. I imagine this is probably PAL.
I'm wondering if i need to transcode this before editing in FCP7. If so then I will use compressor...i imagine the DV PAL setting?
thank you
Shane Ross
Re: just received footage i need to edit into another music video - do i need to transcode this for FCP7?
on Dec 26, 2014 at 4:06:53 am
Should be fine as is...DV/PAL. Bring it in and drag it into a new sequence and you should be good to go.
Shane
Little Frog Post
