adding logo in fcp
Ronald Hoeben
adding logo in fcp
on Dec 21, 2014 at 9:09:52 am
I'm trying to put a logo in my videos. So far i've had MPegStreamclip put in a watermark, buth thats just letters. I have a .png on a piece of white background, how can I save that in order to access it everytime I make a new video? Same goes for a title strip I've made. Is it OK to just save it as a .mov file and import it every time or is there a better way? Thnks.
Shane Ross
Re: adding logo in fcp
on Dec 21, 2014 at 8:33:15 pm
You need to put the logo on a transparent background. Take it into Photoshop, copy it onto a new transparent document...erase everything around the logo you don't want to see (so like the white background it is on, for example)...and then save that as a Photoshop doc. Might be able to retain transparency if you save as a PNG as well. then bring that into FCP...the transparency should be retained. Then resize and move it to where you want it to go...and posibly make it semi transparent...
Shane
Little Frog Post
