FCS partial install for now (just FCP 7) and add other apps (ie. Motion) later
raju bhai
on Dec 21, 2014 at 8:42:23 am
I have the full Final Cut Studio (version 3 or 5) package. But but for now i only want to install the FCP7 and Compressor apps (limited space on my travel laptop). Would i be able to add the Motion app at a later date or would i end up having to do the entire installation (including fcp7) over again?
Shane Ross
Re: FCS partial install for now (just FCP 7) and add other apps (ie. Motion) later
on Dec 21, 2014 at 8:35:08 pm
Yes, you can do that. Just do a CUSTOM INSTALL in both cases.
NOTE: If you are installing on a computer running MacOS 10.9 Mavericks or 10.10 Yosemite, the version of Compressor that comes with FCP 7 (Final Cut STudio 3)...doesn't work. A resource it needs isn't available in the last two os versions...or something. It just doesn't work...SUBMIT option is greyed out.
Shane
Little Frog Post
Nick Meyers
on Dec 21, 2014 at 11:20:56 pm
yes, like Shane says you can do a custom install.
note also that when you do that you have the option of installing Motion without the templates and animations,
which means it's a very small install, and may be worth doing.
(same for DVDSP and STP)
nick
