easy setup to correspond with sequence settings?
raju bhai
on Dec 6, 2014 at 11:28:17 pm
Hello
The setting of all my source clips is:
apple prores422, 1920 x 1080, 23.98fps
the sequence setting for my project which uses all above source clips is:
apple prores422, 1920 x 1080 HDTV 1080i (16:9), 23.98fps, pixel aspect ratio: square
given this, what should the settings be for "easy setup"?
Shane Ross
Re: easy setup to correspond with sequence settings?
on Dec 7, 2014 at 12:10:36 am
NO need to adjust the Easy Setup. Your sequence and footage match.
Shane
Little Frog Post
Michael Gissing
on Dec 7, 2014 at 3:48:42 am
Always a good idea that Easy Setup matches your sequence if you are using a card like Kona or Decklink to view to an external monitor.
Also if you import wav files your frame rates must match. So Easy Setup and sequence must be the same or the wrong frame rate can be stamped onto the wav file and it will not run at correct speed.
