best way to convert frame rate
Nelson May
on Dec 2, 2014 at 11:09:26 am
I am doing a favor for a friend and making a demo real. I have downloaded some HD Video from Vimeo and and going to cut it with video ripped from a DVD.
The video from Vimeo is 24fps and I need to convert it to 30fps.
I have never used cinema tools, but can I do this in compressor fairly easily, or do I have to use cinema tools.
I have FCP 3. Just looking at my easy options. I have been having trouble converting frame rate. I don't know if it is the download from Vimeo or not.
Cheers.
MBP 2.4GHz 4MB RAM, 30"cine, MAC PRO 2.6 8 core 6GB RAM, Mbox, Neumann TLM-103, FCP HD 7. Pro Tools 8, Adobe Creative Suite, Reason 3.0, Macromedia Studio, ProAnimator, HVX200 with Firestore v4.0
Shane Ross
Re: best way to convert frame rate
on Dec 2, 2014 at 5:24:46 pm
Well, 24p to 30p is easy, but won't look all that smooth. because 6 frames will need to repeat in order to get 30 frames out of 24. This looks a lot smoother when you can use interlaced formats...30i. But the web doesn't like interlaced, only TV does.
Simply use compressor and change the frame rate. Cinema Tools will speed the footage up by20%, and you don't want that.
Shane
Little Frog Post
