XAVC-S to ProRes conversion issue
josh wann
on Dec 1, 2014 at 7:33:53 pm
I recently shot with the Sony A7S. I converted the footage to ProRes with Brorsoft Video Converter, which seemed to work fine (however it has limited options). My problem is that some footage I shot at 30fps or 60fps with the intention of conforming it with Cinema Tools to 24fps. It won't recognize the clip and won't even let me open the ProRes file. Any idea why this is?
Is there a better way to convert XAVC-S footage?
Mike Woodworth
Re: XAVC-S to ProRes conversion issue
on Dec 1, 2014 at 9:25:40 pm
My recommendation is EditReady (but I'm slightly partial as the app's developer).
http://www.divergentmedia.com/editready
mike
Shane Ross
on Dec 1, 2014 at 9:54:14 pm
I can attest that he's not a spammer. I own and use EditReady for many tapeless formats. Haven't had the pleasure of Sony A7, but this does great with all the other formats I use.
Shane
Little Frog Post
Jane Kong
on Mar 2, 2015 at 9:13:14 am
I find that brosoftware was extreamly similar with the Pav, and I don't which one may be the best but seems like they all do the same thing. anyway , if this bro one didn't work, you can try the another. Or EditReady is also worth trying.
