Sequence discoloration.. color has changed somehow on whole sequence
Paul Boone
on Nov 29, 2014 at 4:59:42 pm
I'm opening old projects to fix them up for my portfolio, and when I try to open my project in FCP 7, my whole sequence is wierdly colored. The blacks go to pure black really easily, and everyone looks like they've had a ridiculous amount of tanning, because of an orange tint.
What's going on? I'm using the OS Yosemite. Does FCP 7 work in Yosemite?
Does it have something to do with "LUT" or something like that, I don't know much about..
Help!
Daniel Waldron
Re: Sequence discoloration.. color has changed somehow on whole sequence
on Nov 29, 2014 at 5:13:16 pm
Final Cut Pro is not supported in Yosemite. That could easily be your issue. Unfortunately, I don't have a solution other than to get access to a computer with FCP and and older OS.
Michael Gissing
on Nov 30, 2014 at 10:52:56 pm
Is this just computer monitoring or can you view to an external monitor via a card like Kona or Decklink?
Alternatively does the changed gamma and color translate when you render a file out and check it on other software?
Check also that your Easy Setup matches your sequence settings.
