Interview of 2 people
Jim Reed
on Nov 24, 2014 at 4:51:32 pm
I need to make a video that has two different people on two separate cameras views.
When I get both videos on the timeline you can only hear audio from the selected video. I need this to run so when one person stops talking, you can hear the next person talking. I have a split screen set up, but I need help on getting the audio fixed.
Mark Suszko
Re: Interview of 2 people
on Nov 24, 2014 at 5:55:27 pm
Can you show a screen grab of your timeline?
Jim Reed
on Nov 24, 2014 at 6:06:26 pm
What is a grab?
Shane Ross
on Nov 24, 2014 at 7:12:19 pm
Make more audio tracks. Have at least 4. Two for the first interview...so A1 and A2. And then two for the other interview...A3 and A4. This way you can layer the audio if you want.
Shane
Little Frog Post
Jim Reed
on Nov 24, 2014 at 7:16:20 pm
[Shane Ross] "Make more audio tracks. Have at least 4. Two for the first interview...so A1 and A2. And then two for the other interview...A3 and A4. This way you can layer the audio if you want."
That did the trick. Plays perfect.
Thank you all very much.
John Rofrano
on Nov 24, 2014 at 7:14:43 pm
[Jim Reed] "What is a grab?"
A capture of your screen so that we can see your timeline. Use Command + Shift + 3 to create a copy of your screen as an image on your desktop. Then upload that image and add it to your post using the Image Upload button above where you are typing:
~jr
http://www.johnrofrano.com
http://www.vasst.com
