Need to reduce glare
Jay Burgess
on Nov 18, 2014 at 10:21:05 pm
A client had me shoot some footage in a kitchen and the cabinets are fairly glossy stained wood. My lights reflect on the cabinets to where they appear as glowing orbs on the cabinet doors.
What's the best way to reduce this glare? Do I need to use mattes? Is there some combination of effects that will work?
Mark Suszko
Re: Need to reduce glare
on Nov 19, 2014 at 6:31:52 am
Best answer is a re-shoot. Failing that, what David says. One other way to go would be to rotoscope each frame by hand in photoshop, using the clone and healing brushes to paint out the burns. But you need experience to do this and not make it look worse.
