Highest Quality Export w/ mpeg-4 container & H.264 Codec FCPX
Josh Birch
on Nov 13, 2014 at 2:51:49 pm
Hi Guys,
What is the highest possible export option with an mpeg-4 container (.mp4) with a H.264 codec. My client is asking for this format but can't figure it out? Know it seem's a basic question but just wanting the highest quality export
When I go to Export > Master File it only gives me an option for .mov container with H.264 codec....
Thanks in advance
Josh
John Rofrano
Re: Highest Quality Export w/ mpeg-4 container & H.264 Codec FCPX
on Nov 17, 2014 at 2:25:15 am
[Josh Birch] "When I go to Export > Master File it only gives me an option for .mov container with H.264 codec...."
You can use File | Share | Apple Devices 1080p then go to the Settings tab and change Video Codec to H.264 Better Quality and render with that. This will produce a file with an extension of .m4v which you can safely rename to .mp4 if that's what your customer wants. Both simply indicate that are MPEG4 files.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Josh Birch
on Nov 18, 2014 at 9:24:32 am
Should have mentioned that the footage was shot in 720p. Do you just do the same with Apple Devices 720p and then change the codec?
Josh
Josh
http://www.josh-birch.co.uk
John Rofrano
on Nov 18, 2014 at 3:53:09 pm
Yes, use Apple Devices 720p.
~jr
