Video slightly blurred with titles
Louis Basslines
on Nov 7, 2014 at 1:59:35 am
Video very clear when stopped, when I hit play it blurs slightly. I have a track above with a keyframe logo. When I uncheck title track the video plays clear. I rebooted FCP and it came back fine but so I rendered all. Suddenly a bunch of renders dropped off and the video is slightly blurred again with title track above.
Any thoughts ?
Macbook Pro 2.8Ghz Intel core duo 4GB ram OS10.6.6
FCP 7
Nick Meyers
Re: Video slightly blurred with titles
on Nov 7, 2014 at 2:54:21 am
re-render?
nick
Michael Gissing
on Nov 7, 2014 at 6:03:40 am
Is your sequence DV codec?
David Roth Weiss
on Nov 7, 2014 at 5:09:45 pm
[Michael Gissing] "Is your sequence DV codec?
Yep, that's also certainly another possibility.
Even if you are editing DV your sequence settings should be changed to Pro Res, which will keep your titles and graphics in 4:2:2 color space, meaning a whole lot less interpolation of missing pixels will take place. DV works in 4:2:0 color space, which chucks out loads of pixels due to its much lower color space and inferior older compression algorithm.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions
David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
David Roth Weiss
on Nov 7, 2014 at 5:00:36 pm
[Nick Meyers] "re-render?"
Yes, and make certain that your sequence RENDER ALL settings have FULL checked prior to rendering.
David Roth Weiss
