Recently Upgraded Computer, FCP 7 still exports super slow.
Dave Farese
on Oct 23, 2014 at 5:45:49 am
So I just upgraded my Imac 27" (Late 2012) from 8gbs of ram to 32gbs.
I was hoping this would fix my FCP7 export issues but guess what, its still slow as hell.
Like for an export of a 2 hour edit it takes around 12 hours.
I just want to get this thing going faster but i dont know what to do.
Ive tried exporting directly through FCP7, and sending to compressor.
Does anyone have any ideas?
let me know if you need more info.
Shane Ross
Re: Recently Upgraded Computer, FCP 7 still exports super slow.
on Oct 23, 2014 at 8:06:55 am
The only thing that speeds up exports are processor speeds. Unless you are exporting to H.264, then there are a handful of hardware add-ons that help. Like the Elgato Turbo264. Use their presets, and it'll speed things up a lot. There are other converter options, but they won't work with the iMac.
RAM helps very little with conversion speed. It helps with apps that crave RAM....FCP doesn't. It tops out at 4GB. Compressor doesn't use much either. You can see if enabling QMASTER will help. But that requires a 4 core machine or better. Is your iMac a quad core machine?
http://www.kenstone.net/fcp_homepage/compressor_multi_cores_stitzer.html
Shane
Little Frog Post
Dave Farese
on Oct 23, 2014 at 8:14:38 am
im using 3.2 GHz Intel Core i5 which i believe is only dual core.
Can you tell me more about this elgato turbo 264! what is it?
is buying a better processor for my machine even doable on a mac? if so is it worth it?
Shane Ross
on Oct 23, 2014 at 3:14:40 pm
Ugh...looks like they no longer make the Turbo264. And no, you cannot upgrade a processor on a Mac. Only way to get better processor is to buy new machine. Apple's great marketing ploy.
Shane
Little Frog Post
Andrew Kimery
on Oct 23, 2014 at 5:27:55 pm
Out of curiosity what codec is your source footage and what codec are you exporting to?
Dave Farese
on Oct 23, 2014 at 9:59:43 pm
Hey SHane,
is this what you are refering to?
Ill totally buy it if you think it will make my exports faster.
https://www.elgato.com/en/video/turbo-264-hd-software
Andrew: im using aplepro res 422 in fcp and then exporting to h.264
Andrew Kimery
on Oct 24, 2014 at 1:52:38 am
[Dave Farese] "Andrew: im using aplepro res 422 in fcp and then exporting to h.264"
Well, there goes my suggestion for transcoding footage to ProRes to help with export times. ;)
Sascha Engel
on Nov 4, 2014 at 10:07:15 pm
I second Andrew, export first the same codec you sued on your TL, meaning in ProRes. Then drop the finished export in Compressor and take it there to H.264.
It will go faster, you have more control and easier over the settings, and in my experience it also looks better.
Greetings,
Sascha Engel
TIME BANDITZ Productions
http://www.youtube.com/taikang
