Global Audio Pan Change?
joe zabrosky
on Oct 7, 2014 at 3:59:38 pm
Is there a way to globally change your left and right audio channel pan in a two hour project. I'm presently manually changing every clip. Doesn't hurt to ask.
Thanks, joe
joseph zabrosky
Mark Suszko
Re: Global Audio Pan Change?
on Oct 7, 2014 at 4:05:22 pm
Fix the pan on the first clip. copy the clip, highlight ll the other audio clips, right click to find "paste attributes" and select pan from there.
joe zabrosky
on Oct 7, 2014 at 7:04:16 pm
THANK YOU SO MUCH!!!!!!!!!!!!!!! I'm suppose to know how to do that but forgot. Thanks again!
joseph zabrosky
Mark Suszko
on Oct 7, 2014 at 8:02:22 pm
Just help someone else out when you know you know the answer, sometime.
