fcp 7 audio filter won't take effect
Eric Rosenfeld
on Oct 6, 2014 at 11:41:59 pm
How do you get audio filters, such as compressor, to actually take effect? I can drag the filter onto the clip from the effects tab in the browser, and the filter tab will show up in the viewer with all the settings and parameters, but it won't actually change the audio track in any way. The waveforms just stay the same. Is there no 'confirm' or 'submit' or 'apply' type of command?
Dave LaRonde
Re: fcp 7 audio filter won't take effect
on Oct 7, 2014 at 12:20:27 am
Whar are your RT settings? That's the little switch in the upper corner of the timeline.
Dave LaRonde
Promotion Producer
Eric Rosenfeld
on Oct 9, 2014 at 8:18:19 pm
I have it as:
Unlimited RT
High quality playback
Full frame rate
Multiclip playback
Full quality record to tape
Dave LaRonde
on Oct 9, 2014 at 9:37:50 pm
Try using the FCP Render Manager. Open up you project's render files, and delete ALL the audio render files. See what happens.
Dave LaRonde
Promotion Producer
