Final Cut is throwing an error message & not exporting the footage
Lisa Rudnitsky
on Sep 30, 2014 at 3:06:25 am
I can't seem to export media. It seems as though there is a pause in the system but nothing happens.
When I try using compressor or export using compressor settings iFinalCut Pro is throwing error "The operation couldn't be completed (com.apple.compressor.compressorKit.Err or Domain errror -1).
I need to render out footage and can't get it to work. Please advise.
(the only change to my Final Cut/Mac is that it recently had me update the IOS).
Daniel Waldron
Re: Final Cut is throwing an error message & not exporting the footage
on Oct 1, 2014 at 3:57:06 pm
What did you update your OS to? Final Cut Pro 7 and under are no longer supported by Apple, so updating the OS can be risky business. If it worked fine before the update, that is almost definitely the culprit.
