DVD footage best workflow for using it in a HD sequence
Joe Riggs
on Sep 27, 2014 at 2:25:40 pm
I have a project where the majority of the footage is 1080p 23.976 and I'm working in those sequence settings.
I'll need to combine some footage from a DVD into this sequence, the DVDs are standard definition and interlaced.
What's the best workflow (and programs) to get the footage off these DVD's, de-interlace them, convert them to 23.976 and possibly
scale them up using a plug in?
I can work within Premiere if that would be beneficial instead of FCP7.
Thank you
Shane Ross
Re: DVD footage best workflow for using it in a HD sequence
on Sep 28, 2014 at 12:08:08 am
If you have premiere pro, best to use that. Not only can it access the DVD media without converting, but it up scales better than FCP. By a longshot. And also does frame rate mixing better.
If you do need to rip, do the deinterlace when you rip. MPEG streamclip does this
Shane
Little Frog Post
