"Final Cut Pro quit unexpectedly while using Final Cut Pro plug-in"
gabe miller
on Sep 26, 2014 at 8:28:15 pm
Hi, I have a FCP 7 project that crashes shortly after opening. I've deleted preferences, and gone back through auto-save files. After a certain date in the autosave files (late May, 2014) the projects crash. I have worked in the projects in June with no problems, so this seems to be something that started since coming back to the project yesterday (Sept. 25).
I'm on a Macbook Pro Retina running OS 10.9.2, and FCP 7.0.3.
The error pop up reads: "Final Cut Pro quit unexpectedly while using the Final Cut Pro Plug-in"; I don't think I've added plug-ins in over a year.
Apple no longer supports FCP 7, so they sent me to the forums and I've found zero solutions in the database of posts so I'd really appreciate any and all suggestions.
Thanks for reading, and thanks in advance for any advice.
Here's the crash report:
Process: Final Cut Pro [3222]
Path: /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
Identifier: com.apple.FinalCutPro
Version: 7.0.3 (7.0.3)
Build Info: FCPApp-1008261348~8
Code Type: X86 (Native)
Parent Process: launchd [218]
Responsible: Final Cut Pro [3222]
User ID: 501
PlugIn Path: /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
PlugIn Identifier: com.apple.FinalCutPro
PlugIn Version: 7.0.3 (7.0.3)
Date/Time: 2014-09-26 16:16:51.265 -0400
OS Version: Mac OS X 10.9.2 (13C64)
Report Version: 11
Anonymous UUID: 92BB0FD9-2CCA-B745-10CA-BD833C762066
Sleep/Wake UUID: 18B23649-87C8-40B5-91D2-3E7FA02560B0
Crashed Thread: 3
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000048
VM Regions Near 0x48:
--> __PAGEZERO 0000000000000000-0000000000001000 [ 4K] ---/--- SM=NUL /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
__TEXT 0000000000001000-0000000000871000 [ 8640K] r-x/rwx SM=COW /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
Thread 0:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x0426a0a6 mach_wait_until + 10
1 libsystem_c.dylib 0x041cdc4a nanosleep + 366
2 libsystem_c.dylib 0x041cda7d usleep + 60
3 com.apple.FinalCutPro 0x00426a3e FCPMediaHandler::WaitForDisplayQueueToEmpty() + 32
4 com.apple.FinalCutPro 0x0042d416 FCPMediaHandler::Idle(long, long, long*, TimeRecord*) + 4828
5 com.apple.FinalCutPro 0x0042d495 FCPMHIdle(FCPMediaHandler*, long, long, long*, TimeRecord*) + 45
6 com.apple.CoreServices.CarbonCore 0x05983618 callComponentStorage_44444 + 47
7 com.apple.CoreServices.CarbonCore 0x05971cd7 CallComponentFunctionCommonWithStorage(char**, ComponentParameters*, long (*)(), unsigned long) + 45
8 com.apple.CoreServices.CarbonCore 0x05971d17 CallComponentFunctionWithStorageProcInfo + 30
9 com.apple.FinalCutPro 0x00426221 FCPMHDispatch(ComponentParameters*, char**) + 59
10 com.apple.CoreServices.CarbonCore 0x058e3c45 CallComponent + 166
11 com.apple.CoreServices.CarbonCore 0x058e3c9f CallComponentDispatch + 29
12 com.apple.QuickTimeComponents.component 0x2d1fee19 0x2c9f4000 + 8433177
13 com.apple.QuickTimeComponents.component 0x2ccb4395 0x2c9f4000 + 2884501
14 com.apple.QuickTimeComponents.component 0x2ccb3ebe 0x2c9f4000 + 2883262
15 com.apple.CoreServices.CarbonCore 0x05983618 callComponentStorage_44444 + 47
16 com.apple.CoreServices.CarbonCore 0x05971cd7 CallComponentFunctionCommonWithStorage(char**, ComponentParameters*, long (*)(), unsigned long) + 45
17 com.apple.CoreServices.CarbonCore 0x05971d17 CallComponentFunctionWithStorageProcInfo + 30
18 com.apple.QuickTimeComponents.component 0x2ccb37e9 GenericComponentDispatch + 93
19 com.apple.CoreServices.CarbonCore 0x058e3c45 CallComponent + 166
20 com.apple.CoreServices.CarbonCore 0x058e3cbc DelegateComponentCall + 24
21 com.apple.FinalCutPro 0x0042623d FCPMHDispatch(ComponentParameters*, char**) + 87
22 com.apple.CoreServices.CarbonCore 0x058e3c45 CallComponent + 166
23 com.apple.CoreServices.CarbonCore 0x058e3c9f CallComponentDispatch + 29
24 com.apple.QuickTime 0x011c826a MediaMoviesTask + 61
25 com.apple.QuickTime 0x011c7670 TaskMovie_priv + 4167
26 com.apple.QuickTime 0x011d507d MoviesTask_priv + 87
27 com.apple.FinalCutPro 0x001ba928 DoMoviesTask(KGPlayerRec*) + 2388
28 com.apple.FinalCutPro 0x001cd651 DisplayMovie(KGPlayerRec*) + 2201
29 com.apple.FinalCutPro 0x001d1b48 pKGPlayerUpdate(KGPlayerRec*) + 196
30 com.apple.FinalCutPro 0x001bac1d DelayTimer(long, long, KGDictInt*, void*) + 89
31 com.apple.FinalCutPro 0x00150000 KGTimerInvoke(__EventLoopTimer*, void*) + 212
32 com.apple.HIToolbox 0x074b1a6b TimerVector + 22
33 com.apple.CoreFoundation 0x00d29f46 __CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUNCTION__ + 22
34 com.apple.CoreFoundation 0x00d29903 __CFRunLoopDoTimer + 1395
35 com.apple.CoreFoundation 0x00da406d __CFRunLoopDoTimers + 349
36 com.apple.CoreFoundation 0x00ce1483 __CFRunLoopRun + 1779
37 com.apple.CoreFoundation 0x00ce0b1a CFRunLoopRunSpecific + 394
38 com.apple.CoreFoundation 0x00ce097b CFRunLoopRunInMode + 123
39 com.apple.HIToolbox 0x074a0b7d RunCurrentEventLoopInMode + 259
40 com.apple.HIToolbox 0x074a0797 ReceiveNextEventCommon + 163
41 com.apple.HIToolbox 0x074ebaea AcquireNextEventInMode + 75
42 com.apple.HIToolbox 0x0763b9da _AcquireNextEvent + 58
43 com.apple.HIToolbox 0x0762a4ac _RunAppModalLoop + 168
44 com.apple.HIToolbox 0x0762a3be RunAppModalLoopForWindow + 130
45 com.apple.FinalCutPro 0x002a8583 pKGDialogRun(KGPanelRecord*, unsigned char, unsigned char, KGDictInt*) + 755
46 com.apple.FinalCutPro 0x00285ac4 pKGNotifyFilesOffline(KGDictInt*, long) + 1990
47 com.apple.FinalCutPro.Plugins.Browser 0x308523f8 BrowserOpenFile(KGFileRec*, unsigned char, unsigned char, KGDictInt**) + 5718
48 com.apple.FinalCutPro.Plugins.Browser 0x30854f11 Browser(long, long, KGDictInt*, KGFileRec*) + 10299
49 com.apple.FinalCutPro 0x0018c472 CheckForOpenFile(KGFileSpec*, char*, unsigned char, unsigned char, KGDictInt**) + 488
50 com.apple.FinalCutPro 0x0018c5a6 pKGDisplayFile(KGFileSpec*, char*, unsigned char, unsigned char) + 44
51 com.apple.FinalCutPro 0x00412af2 OpenDocuments(AEDesc const*, AEDesc*, long) + 354
52 com.apple.AE 0x05eeeb15 aeDispatchAppleEvent(AEDesc const*, AEDesc*, unsigned long, unsigned char*) + 387
53 com.apple.AE 0x05ebded6 dispatchEventAndSendReply(AEDesc const*, AEDesc*) + 44
54 com.apple.AE 0x05ebddce aeProcessAppleEvent + 318
55 com.apple.HIToolbox 0x074ae591 AEProcessAppleEvent + 55
56 com.apple.HIToolbox 0x0763bcaa AEProcessEvent + 167
57 com.apple.HIToolbox 0x0753d49a HIStdAppHandler::HandleEvent(OpaqueEventHandlerCallRef*, TCarbonEvent&) + 76
58 com.apple.HIToolbox 0x0753e506 TEventHandler::EventHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 60
59 com.apple.HIToolbox 0x07629d89 _InvokeEventHandlerUPP(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*, long (*)(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*)) + 36
60 com.apple.HIToolbox 0x0747d35f DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1452
61 com.apple.HIToolbox 0x0747c678 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 386
62 com.apple.HIToolbox 0x0747c4f0 SendEventToEventTargetWithOptions + 94
63 com.apple.HIToolbox 0x074b0479 ToolboxEventDispatcherHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 1757
64 com.apple.HIToolbox 0x0747d7a5 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 2546
65 com.apple.HIToolbox 0x0747c678 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 386
66 com.apple.HIToolbox 0x0748f821 SendEventToEventTarget + 88
67 com.apple.HIToolbox 0x07629473 ToolboxEventDispatcher + 82
68 com.apple.HIToolbox 0x07629333 RunApplicationEventLoop + 240
69 com.apple.FinalCutPro 0x001539d1 KGMainEvent(void*) + 51
70 com.apple.FinalCutPro 0x002c1278 main + 54
71 com.apple.FinalCutPro 0x00002d5b _start + 209
72 com.apple.FinalCutPro 0x00002c89 start + 41
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib 0x0426f992 kevent64 + 10
1 libdispatch.dylib 0x040ca8ad _dispatch_mgr_invoke + 238
2 libdispatch.dylib 0x040ca546 _dispatch_mgr_thread + 52
Thread 2:: com.apple.CFSocket.private
0 libsystem_kernel.dylib 0x0426eace __select + 10
1 com.apple.CoreFoundation 0x00d31b86 __CFSocketManager + 1158
2 libsystem_pthread.dylib 0x0435f5fb _pthread_body + 144
3 libsystem_pthread.dylib 0x0435f485 _pthread_start + 130
4 libsystem_pthread.dylib 0x04364cf2 thread_start + 34
Thread 3 Crashed:
0 com.apple.GeForceGLDriver 0x48317a0b 0x48000000 + 3242507
1 com.apple.GeForceGLDriver 0x4831791a 0x48000000 + 3242266
2 com.apple.GeForceGLDriver 0x48211e1c 0x48000000 + 2170396
3 com.apple.GeForceGLDriver 0x482f5d18 0x48000000 + 3104024
4 com.apple.GeForceGLDriver 0x48308252 0x48000000 + 3179090
5 com.apple.GeForceGLDriver 0x48205ef0 0x48000000 + 2121456
6 com.apple.GeForceGLDriver 0x48610bec 0x48000000 + 6360044
7 com.apple.GeForceGLDriver 0x482cf329 0x48000000 + 2945833
8 com.apple.GeForceGLDriver 0x4832fa59 0x48000000 + 3340889
9 libGPUSupportMercury.dylib 0x2d7e5e11 gldUpdateDrawFramebuffer + 113
10 GLEngine 0x2eb0fac4 gleUpdateDrawFramebufferState + 510
11 GLEngine 0x2eb112cf gleDoDrawDispatchCore + 99
12 GLEngine 0x2ea38131 glBegin_Exec + 112
13 com.apple.FinalCutPro 0x0043fc04 CopyPBufferToContext(__AGLPBufferRec*, unsigned int, float, float, __AGLContextRec*, CGRect const&, bool, bool) + 176
14 com.apple.FinalCutPro 0x00444011 DisplayContext::RenderToContexts_Fragment(KGTexture const*, __AGLPBufferRec*, CGRect const&) + 757
15 com.apple.FinalCutPro 0x004444f4 DisplayContext::OGLDraw(RTBufferRef const&, RTBufferRef const&) + 1184
16 com.apple.FinalCutPro 0x00427624 FCPMediaHandler::DisplayOutput(Output*) + 1596
17 com.apple.FinalCutPro 0x00429159 DisplayQueue::Run() + 739
18 com.apple.FinalCutPro 0x0046b49a Thread::RunHelper(void*) + 20
19 libsystem_pthread.dylib 0x0435f5fb _pthread_body + 144
20 libsystem_pthread.dylib 0x0435f485 _pthread_start + 130
21 libsystem_pthread.dylib 0x04364cf2 thread_start + 34
Thread 4:
0 libsystem_kernel.dylib 0x0426e7ca __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x04361d8a _pthread_cond_wait + 837
2 libsystem_pthread.dylib 0x04363fa3 pthread_cond_wait + 48
3 com.apple.FinalCutPro 0x0043f42b Synchronizable::Wait() + 53
4 com.apple.FinalCutPro 0x004e67c3 WorkUnitPerformer::Run() + 55
5 com.apple.FinalCutPro 0x0046b49a Thread::RunHelper(void*) + 20
6 libsystem_pthread.dylib 0x0435f5fb _pthread_body + 144
7 libsystem_pthread.dylib 0x0435f485 _pthread_start + 130
8 libsystem_pthread.dylib 0x04364cf2 thread_start + 34
Thread 5:
Thread 6:
Thread 7:
0 libsystem_kernel.dylib 0x0426eb76 __semwait_signal + 10
1 libsystem_c.dylib 0x041c6fb7 nanosleep$UNIX2003 + 219
2 libsystem_c.dylib 0x041c6dc2 sleep$UNIX2003 + 45
3 com.redgiantsoftware.mbframes 0x49d522ef RGS::SerialServer::ThreadProcess() + 31
4 com.redgiantsoftware.mbframes 0x49d53f81 RGS::ThreadObject::ThreadFunc(void*) + 17
5 libsystem_pthread.dylib 0x0435f5fb _pthread_body + 144
6 libsystem_pthread.dylib 0x0435f485 _pthread_start + 130
7 libsystem_pthread.dylib 0x04364cf2 thread_start + 34
Thread 8:
3 com.redgiantsoftware.MagicBullet.Cosmo 0x477c433f 0x477a7000 + 119615
4 com.redgiantsoftware.MagicBullet.Cosmo 0x477c60bf 0x477a7000 + 127167
Thread 9:
3 com.redgiantsoftware.InstantHD 0x49fa0f9f RGS::SerialServer::ThreadProcess() + 31
4 com.redgiantsoftware.InstantHD 0x49fa2d47 RGS::ThreadObject::ThreadFunc(void*) + 17
Thread 10:
3 com.redgiantsoftware.looks3fx 0x4ae8a23f CreateDialogWindow(CustomDialogData const&, char const*) + 10219
4 com.redgiantsoftware.looks3fx 0x4ae8bfe7 CreateDialogWindow(CustomDialogData const&, char const*) + 17811
Thread 11:
3 com.redgiantsoftware.MagicBullet.Colorista_II 0x4b50428f 0x4b481000 + 537231
4 com.redgiantsoftware.MagicBullet.Colorista_II 0x4b50600f 0x4b481000 + 544783
Thread 12:
0 libsystem_kernel.dylib 0x04269f7a mach_msg_trap + 10
1 libsystem_kernel.dylib 0x0426916c mach_msg + 68
2 com.apple.CoreFoundation 0x00ce1d29 __CFRunLoopServiceMachPort + 169
3 com.apple.CoreFoundation 0x00ce1301 __CFRunLoopRun + 1393
4 com.apple.CoreFoundation 0x00ce0b1a CFRunLoopRunSpecific + 394
5 com.apple.CoreFoundation 0x00ce097b CFRunLoopRunInMode + 123
6 com.apple.CoreMediaIOServicesPrivate 0x025448fe MIO::DAL::RunLoop::OwnThread(void*) + 174
7 com.apple.CoreMediaIOServicesPrivate 0x02546d40 CAPThread::Entry(CAPThread*) + 96
8 libsystem_pthread.dylib 0x0435f5fb _pthread_body + 144
9 libsystem_pthread.dylib 0x0435f485 _pthread_start + 130
10 libsystem_pthread.dylib 0x04364cf2 thread_start + 34
Thread 13:
5 com.apple.CoreFoundation 0x00da3221 CFRunLoopRun + 129
6 com.apple.qmaster.do 0x5e39d460 swamp::CRAdReceiver2::ReceivingThread::runOnce() + 234
7 com.apple.AECore 0x4ec06022 aecore::CThread::runThread() + 34
8 com.apple.AECore 0x4ec03fb9 threadProc(void*) + 17
10 libsystem_pthread.dylib 0x0435f485 _pthread_start + 130
11 libsystem_pthread.dylib 0x04364cf2 thread_start + 34
Thread 14:
1 com.apple.AECore 0x4ec06067 aecore::CThread::runThread() + 103
2 com.apple.AECore 0x4ec03fb9 threadProc(void*) + 17
3 libsystem_pthread.dylib 0x0435f5fb _pthread_body + 144
4 libsystem_pthread.dylib 0x0435f485 _pthread_start + 130
5 libsystem_pthread.dylib 0x04364cf2 thread_start + 34
Thread 15:
2 libsystem_pthread.dylib 0x04362042 pthread_cond_timedwait_relative_np + 47
3 com.apple.CoreServices.CarbonCore 0x0594e88d TSWaitOnConditionTimedRelative + 161
4 com.apple.CoreServices.CarbonCore 0x0594e44a TSWaitOnSemaphoreCommon + 531
5 com.apple.CoreServices.CarbonCore 0x0594e5fd TSWaitOnSemaphoreRelative + 24
6 com.apple.QuickTimeComponents.component 0x2cc61091 0x2c9f4000 + 2543761
7 libsystem_pthread.dylib 0x0435f5fb _pthread_body + 144
8 libsystem_pthread.dylib 0x0435f485 _pthread_start + 130
9 libsystem_pthread.dylib 0x04364cf2 thread_start + 34
Thread 16:
6 com.apple.CoreServices.CarbonCore 0x058e864c AIOFileThread(void*) + 1014
Thread 17:
0 libsystem_kernel.dylib 0x0426f046 __workq_kernreturn + 10
1 libsystem_pthread.dylib 0x04360dcf _pthread_wqthread + 372
2 libsystem_pthread.dylib 0x04364cce start_wqthread + 30
Thread 18:
Thread 19:
Thread 20:
Thread 21:
Thread 22:
Thread 23:
Thread 24:
Thread 25:
Thread 26:: com.apple.audio.IOThread.client
2 com.apple.audio.CoreAudio 0x01118e9a HALB_MachPort::SendMessageWithReply(unsigned int, unsigned int, unsigned long, unsigned long, mach_msg_header_t*, bool, unsigned int) + 138
3 com.apple.audio.CoreAudio 0x0111334e HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) + 68
4 com.apple.audio.CoreAudio 0x01111b27 HALC_ProxyIOContext::IOWorkLoop() + 1111
5 com.apple.audio.CoreAudio 0x011115ff HALC_ProxyIOContext::IOThreadEntry(void*) + 167
6 com.apple.audio.CoreAudio 0x0111bf52 ___ZN19HALC_ProxyIOContextC2Emj_block_invoke + 20
7 com.apple.audio.CoreAudio 0x011114fb HALB_IOThread::Entry(void*) + 69
Thread 27:
0 libsystem_kernel.dylib 0x04269fce semaphore_timedwait_trap + 10
1 com.apple.CoreServices.CarbonCore 0x0591b071 MPWaitOnSemaphore + 104
2 com.apple.QuickTimeComponents.component 0x2cf558b4 0x2c9f4000 + 5642420
3 com.apple.CoreServices.CarbonCore 0x0591b2ce PrivateMPEntryPoint + 68
4 libsystem_pthread.dylib 0x0435f5fb _pthread_body + 144
5 libsystem_pthread.dylib 0x0435f485 _pthread_start + 130
6 libsystem_pthread.dylib 0x04364cf2 thread_start + 34
Thread 28:
Thread 29:
Thread 30:
Thread 31:
Thread 32:
Thread 33:
Thread 3 crashed with X86 Thread State (32-bit):
eax: 0x483179ee ebx: 0x00000000 ecx: 0x00000009 edx: 0xf5458c28
edi: 0xe09c9730 esi: 0x00000000 ebp: 0xb0229ab8 esp: 0xb0229a70
ss: 0x00000023 efl: 0x00010297 eip: 0x48317a0b cs: 0x0000001b
ds: 0x00000023 es: 0x00000023 fs: 0x00000023 gs: 0x0000000f
cr2: 0x00000048
Logical CPU: 2
Error Code: 0x00000004
Trap Number: 14
Binary Images:
0x1000 - 0x870ffc com.apple.FinalCutPro (7.0.3 - 7.0.3) <41B8A263-80F3-BCC3-FE28-82DE571687A1> /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
0xc2e000 - 0xc2ffff libSystem.B.dylib (1197.1.1) /usr/lib/libSystem.B.dylib
0xc36000 - 0xc36ffd com.apple.audio.units.AudioUnit (1.10 - 1.10) <85316395-817E-342D-8F41-88838EC6FB63> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0xc3c000 - 0xc3fff7 +KGCore (1) /Applications/Final Cut Pro.app/Contents/Frameworks/KGCore.framework/Versions/A/KGCore
0xc47000 - 0xc55ff3 com.apple.opengl (9.6.0 - 9.6.0) <63941A8D-AACC-3C71-BE8C-4DAA913A1439> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0xc5d000 - 0xc64ffe com.apple.agl (3.2.3 - AGL-3.2.3) <3CD7521E-5FEA-34CA-9F40-87EECA27D7C0> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0xc6b000 - 0xe6dfff com.apple.CoreFoundation (6.9 - 855.14) <756998B3-F507-3474-AFB2-769FC9CE5263> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0xfa8000 - 0xfa8fff com.apple.Carbon (154 - 157) <6C29C608-97B4-306E-AEC5-6F48EDF7EFB5> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0xfab000 - 0xffcff1 libstdc++.6.dylib (60) <354F284B-2343-3810-9CA2-E28038824F6E> /usr/lib/libstdc++.6.dylib
0x105c000 - 0x10d1ffb com.apple.framework.IOKit (2.0.1 - 907.90.2) /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x1100000 - 0x1155ff7 com.apple.audio.CoreAudio (4.2.0 - 4.2.0) <0F1C111F-1E64-33BB-A69F-14643B3037D5> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x1178000 - 0x13f4fe7 com.apple.QuickTime (7.7.3 - 2826.17) /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x149d000 - 0x149dffd com.apple.iokit.dvcomponentglue (2.0.7 - 2.0.7) /System/Library/Frameworks/DVComponentGlue.framework/Versions/A/DVComponentGlue
0x14a1000 - 0x16494af libobjc.A.dylib (551.1) <31CBE178-E972-30D1-ADC6-4B8345CAE326> /usr/lib/libobjc.A.dylib
0x1666000 - 0x1675fff com.apple.AERegistration (1.2 - 77) <5D18C47F-6F9E-0C4C-8875-24A14A97186D> /Applications/Final Cut Pro.app/Contents/Frameworks/AERegistration.framework/Versions/A/AERegistration
0x1689000 - 0x1690fff com.apple.AEProfiling (1.2 - 22) <43A46C32-8E13-82DD-8AF1-2A40690BF810> /Applications/Final Cut Pro.app/Contents/Frameworks/AEProfiling.framework/Versions/A/AEProfiling
0x169a000 - 0x1703fff com.apple.SystemConfiguration (1.13 - 1.13) <144317BE-7AE5-3B8D-90CD-62DCDE9399E7> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x1734000 - 0x19a2ff6 com.apple.security (7.0 - 55471.14) <7915499B-66CF-39FE-B53C-A11C7775314D> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x1ac5000 - 0x1ac5fff com.apple.Accelerate (1.9 - Accelerate 1.9) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x1ac8000 - 0x1ac8fff com.apple.Cocoa (6.8 - 20) <407DC9E6-BBCE-3D34-9BBB-00C90584FFDF> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x1acb000 - 0x1c77fff com.apple.QuartzCore (1.8 - 332.3) <00167BF7-E3C4-3AA7-8DA0-466BD4175350> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x1d2d000 - 0x1f5afff com.apple.prokit (7.4.0 - 1957) <21F637BA-FAA7-3CAD-8774-011559AE614E> /System/Library/PrivateFrameworks/ProKit.framework/Versions/A/ProKit
0x2073000 - 0x2073fff com.apple.quartzframework (1.5 - 1.5) <5BB3FDD4-4727-3D1B-9582-C96F36DA1542> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x2076000 - 0x20e8fef com.apple.ProFX (1.2.3 - 1.2.3) <06B47AC3-9449-A6F0-E189-09D4D1E29A5A> /Library/Application Support/ProApps/*/ProFX.framework/Versions/A/ProFX
0x210a000 - 0x227afff com.apple.QTKit (7.7.3 - 2826.17) <962F9FB1-7E46-3F93-9BAF-E05E7CF8D36D> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x2352000 - 0x243dff4 com.apple.DiskImagesFramework (10.9 - 371.1) <3B983A59-C2DB-3CBA-803A-DF5E0E6E4058> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0x248e000 - 0x24eaffb com.apple.proapps.MIO (1.0.5 - 509) <3FE469A6-C937-1E44-F79C-9AAA7C902A92> /Applications/Final Cut Pro.app/Contents/Frameworks/MIO.framework/Versions/A/MIO
0x2527000 - 0x2530ff7 com.apple.finalcutstudio.prometadatasupport (0.6 - 1.0) /Library/Frameworks/ProMetadataSupport.framework/Versions/A/ProMetadataSupport
0x2538000 - 0x256aff2 com.apple.CoreMediaIOServicesPrivate (403.0 - 3322) /System/Library/PrivateFrameworks/CoreMediaIOServicesPrivate.framework/Versions/A/CoreMediaIOServicesPrivate
0x2585000 - 0x25acff7 com.apple.CoreMediaPrivate (20.0 - 20.0) <3FB05F43-4314-3BAA-AEBF-4EBCA84FB866> /System/Library/PrivateFrameworks/CoreMediaPrivate.framework/Versions/A/CoreMediaPrivate
0x25bf000 - 0x25c9ff4 com.apple.iChat.InstantMessage (8.0 - 4203) /System/Library/Frameworks/InstantMessage.framework/Versions/A/InstantMessage
0x25d4000 - 0x2600ff7 com.apple.FWAVCPrivate (71.47 - 47) <2BE9FF56-E096-319A-8E0B-E8CFD8768C21> /System/Library/PrivateFrameworks/FWAVCPrivate.framework/Versions/A/FWAVCPrivate
0x2616000 - 0x2634fef com.apple.XSKey (1.0.0 - 52) <71B94F53-15DB-9012-91F2-211F7C2CD790> /Library/Frameworks/XSKey.framework/Versions/A/XSKey
0x2643000 - 0x2643fff com.apple.CoreServices (59 - 59) <06747539-5035-3307-8645-9BC4E7F89023> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x264c000 - 0x326aff3 com.apple.AppKit (6.9 - 1265.19) <07125263-9E97-3A47-BBD3-6FB462910565> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x37f6000 - 0x37f6fff com.apple.ApplicationServices (48 - 48) <7967F6FA-2984-3CC3-AD9A-7B9AEC562A2A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x37fe000 - 0x3b29ffe com.apple.Foundation (6.9 - 1056.13) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x3cc1000 - 0x3f25ff7 com.apple.CoreData (107 - 481.01) <85EE4DFF-3A61-3D3B-A818-524F0A427A4D> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x3fe8000 - 0x400ffff com.apple.CoreVideo (1.8 - 117.2) /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x4028000 - 0x402cffa libcache.dylib (62) <9730D7F2-D226-3F30-8D26-BF598CB781F6> /usr/lib/system/libcache.dylib
0x4031000 - 0x403cffb libcommonCrypto.dylib (60049) /usr/lib/system/libcommonCrypto.dylib
0x4049000 - 0x404eff6 libcompiler_rt.dylib (35) <9924DF2E-D80B-3A21-920D-544A4597203F> /usr/lib/system/libcompiler_rt.dylib
0x4059000 - 0x4061fff libcopyfile.dylib (103) <1B1484BD-08B6-3BA9-94CA-A7C24B610EB3> /usr/lib/system/libcopyfile.dylib
0x4068000 - 0x40b8ff7 libcorecrypto.dylib (161.1) <135FD99E-2211-3DF4-825C-C9F816107F0C> /usr/lib/system/libcorecrypto.dylib
0x40c7000 - 0x40dfffd libdispatch.dylib (339.90.1) <871AC354-D1B6-3475-889E-AF594448CF43> /usr/lib/system/libdispatch.dylib
0x40f2000 - 0x40f5ff7 libdyld.dylib (239.4) /usr/lib/system/libdyld.dylib
0x40fc000 - 0x40fcfff libkeymgr.dylib (28) <1B097DEA-011E-3B1C-86D5-6C7FAD5C765A> /usr/lib/system/libkeymgr.dylib
0x4101000 - 0x4109fff liblaunch.dylib (842.90.1) /usr/lib/system/liblaunch.dylib
0x4111000 - 0x4115ff7 libmacho.dylib (845) /usr/lib/system/libmacho.dylib
0x411a000 - 0x411cfff libquarantine.dylib (71) /usr/lib/system/libquarantine.dylib
0x4122000 - 0x4123fff libremovefile.dylib (33) /usr/lib/system/libremovefile.dylib
0x4129000 - 0x413bfff libsystem_asl.dylib (217.1.4) <51EB17C9-9F5B-39F3-B6CD-8EF238B05B89> /usr/lib/system/libsystem_asl.dylib
0x4145000 - 0x4146fff libsystem_blocks.dylib (63) <2AC67D5E-ECD4-3644-A53C-9684F9B7AA33> /usr/lib/system/libsystem_blocks.dylib
0x414b000 - 0x41ddff9 libsystem_c.dylib (997.90.3) <80D21D3D-1031-314C-B1F0-0B35B977CEFB> /usr/lib/system/libsystem_c.dylib
0x4205000 - 0x4207fff libsystem_configuration.dylib (596.13) <57095AFE-3FF1-3F42-A43E-ED679409B827> /usr/lib/system/libsystem_configuration.dylib
0x420d000 - 0x4215fff libsystem_dnssd.dylib (522.90.2) /usr/lib/system/libsystem_dnssd.dylib
0x421b000 - 0x4243fff libsystem_info.dylib (449.1.3) /usr/lib/system/libsystem_info.dylib
0x4257000 - 0x4274ff4 libsystem_kernel.dylib (2422.90.20) /usr/lib/system/libsystem_kernel.dylib
0x4295000 - 0x42c6ffa libsystem_m.dylib (3047.16) <28E614E8-7802-3E84-960A-AD4721EF10F7> /usr/lib/system/libsystem_m.dylib
0x42d1000 - 0x42e9ff7 libsystem_malloc.dylib (23.10.1) /usr/lib/system/libsystem_malloc.dylib
0x42f2000 - 0x431dff7 libsystem_network.dylib (241.3) <71EBA489-386D-3608-ADE6-CB50EBD1AB1B> /usr/lib/system/libsystem_network.dylib
0x4337000 - 0x4340fff libsystem_notify.dylib (121) <623269F5-1518-3035-A916-8AF83C972154> /usr/lib/system/libsystem_notify.dylib
0x4348000 - 0x434dff3 libsystem_platform.dylib (24.90.1) <0613F163-9A7A-3908-B30B-AC1627503933> /usr/lib/system/libsystem_platform.dylib
0x435e000 - 0x4365ffb libsystem_pthread.dylib (53.1.4) <8B1B7B84-1B5D-32A8-AC0D-1E689E5C8A4C> /usr/lib/system/libsystem_pthread.dylib
0x436f000 - 0x4370ffa libsystem_sandbox.dylib (278.11) /usr/lib/system/libsystem_sandbox.dylib
0x4375000 - 0x4376ffd libunc.dylib (28) <22A126A1-DCFB-3BE5-A66B-C973F0A5D839> /usr/lib/system/libunc.dylib
0x437c000 - 0x4382ffb libunwind.dylib (35.3) <099D1A6F-A1F0-3D05-BF1C-0A7BB32D39C2> /usr/lib/system/libunwind.dylib
0x4389000 - 0x43adff7 libxpc.dylib (300.90.2) <5ACBBE2C-74EB-3E88-BCBF-C573095318A5> /usr/lib/system/libxpc.dylib
0x43c3000 - 0x4536ffb com.apple.audio.toolbox.AudioToolbox (1.10 - 1.10) /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x45c0000 - 0x45d2fff libbsm.0.dylib (33) <1BE92DB5-0D2F-3BB5-BCC6-8A71EF2A3450> /usr/lib/libbsm.0.dylib
0x45da000 - 0x462ffff libc++.1.dylib (120) <10C0A136-64F9-3CC2-9420-013247032120> /usr/lib/libc++.1.dylib
0x4686000 - 0x4970fd2 com.apple.vImage (7.0 - 7.0) <256972F0-3DBC-3CE1-9EE8-B48243868729> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x49ad000 - 0x49adfff com.apple.Accelerate.vecLib (3.9 - vecLib 3.9) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x49b0000 - 0x4a80fef libvDSP.dylib (423.32) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x4a8c000 - 0x4ab0ff3 libc++abi.dylib (49.1) <43A04ACF-97A5-35ED-B454-6B5C0CF0F99D> /usr/lib/libc++abi.dylib
0x4abc000 - 0x4b68ffb libvMisc.dylib (423.32) <43873EFF-FB43-3301-BEE8-F2C3A046D7A6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x4b73000 - 0x4f38ff6 libLAPACK.dylib (1094.5) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x4f8f000 - 0x50e5ff0 libBLAS.dylib (1094.5) <74310C2F-4FDB-3995-A01A-5AFB83010A43> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x510a000 - 0x5147ff7 libauto.dylib (185.5) /usr/lib/libauto.dylib
0x515d000 - 0x515efff libDiagnosticMessagesClient.dylib (100) /usr/lib/libDiagnosticMessagesClient.dylib
0x5163000 - 0x5329ffb libicucore.A.dylib (511.31) <9C25D145-E785-357B-9833-1980A1A738C9> /usr/lib/libicucore.A.dylib
0x53bd000 - 0x53cbff7 libz.1.dylib (53) <858B4D9F-D87E-3D81-B07A-DF9632BD185F> /usr/lib/libz.1.dylib
0x53d1000 - 0x53ddfff libkxld.dylib (2422.90.20) <28EAB745-E690-34E7-B9F0-BD05E507173B> /usr/lib/system/libkxld.dylib
0x53e2000 - 0x53f0fff libxar.1.dylib (202) /usr/lib/libxar.1.dylib
0x53f8000 - 0x550affc libsqlite3.dylib (158) /usr/lib/libsqlite3.dylib
0x5521000 - 0x5525ffc libpam.2.dylib (20) <50623D44-795F-3E28-AA85-23E0E7E2AE0E> /usr/lib/libpam.2.dylib
0x552a000 - 0x552affd libOpenScriptingUtil.dylib (157) <4D06E8ED-D312-34EA-A448-DFF45ADC3CE5> /usr/lib/libOpenScriptingUtil.dylib
0x552e000 - 0x553affc libbz2.1.0.dylib (29) <3CEF1E92-BA42-3F8A-8E8D-9E1F7658E5C7> /usr/lib/libbz2.1.0.dylib
0x5540000 - 0x562cff7 libxml2.2.dylib (26) <32040145-6FD6-3AD2-B98B-39F73BF9AC47> /usr/lib/libxml2.2.dylib
0x565b000 - 0x57bdff3 com.apple.CFNetwork (673.2.1 - 673.2.1) <6EA58F7C-35E9-37BF-A6B4-7DDB83A6B432> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x588f000 - 0x5b90ffb com.apple.CoreServices.CarbonCore (1077.17 - 1077.17) <02C72D54-E3D3-32B0-A081-E85A7038489D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x5c07000 - 0x5c9fff7 com.apple.Metadata (10.7.0 - 800.23) <6590358F-9677-3257-8780-FF0462852EDD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x5cf0000 - 0x5d70ff7 com.apple.CoreServices.OSServices (600.4 - 600.4) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x5e05000 - 0x5e78fff com.apple.SearchKit (1.4.0 - 1.4.0) <6F607AB6-7553-37BA-BEC5-98FD7C27FAD7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x5eb3000 - 0x5f11ffd com.apple.AE (665.5 - 665.5) <54F2F247-160C-3A22-A6E3-5D49655A67AB> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x5f3d000 - 0x6018ff7 com.apple.LaunchServices (572.26 - 572.26) <5915A9AC-7928-30B1-9329-94048ADE81D9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x6081000 - 0x60adff7 com.apple.DictionaryServices (1.2 - 208) <33873336-BECD-3F62-A315-C45F24C1818C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x60cd000 - 0x60d6fff com.apple.DiskArbitration (2.6 - 2.6) <92F7575A-AA20-34D9-BB26-2CC8C3CCAFEB> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x60e0000 - 0x60e7ff2 com.apple.NetFS (6.0 - 4.0) <915AA303-C02B-3B0C-8208-D8AAA4350DB4> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x60ee000 - 0x60f9ff6 com.apple.NetAuth (5.0 - 5.0) <3B2E9615-EE12-38FC-BDCF-09529FF9464B> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x6105000 - 0x6106fff liblangid.dylib (117) /usr/lib/liblangid.dylib
0x610a000 - 0x6126fff libCRFSuite.dylib (34) /usr/lib/libCRFSuite.dylib
0x6130000 - 0x6199ffa com.apple.datadetectorscore (5.0 - 354.3) <566882DE-B726-331E-BA89-ACBB3D5BEEC4> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x61c9000 - 0x61ccff9 com.apple.TCC (1.0 - 1) /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x61d2000 - 0x61eafff com.apple.CFOpenDirectory (10.9 - 173.90.1) <13B70F7C-9A4D-3CCA-AEB8-3958F5B6167E> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x6202000 - 0x620cfff com.apple.bsd.ServiceManagement (2.0 - 2.0) /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x6215000 - 0x623ffff libxslt.1.dylib (13) <249D54AB-1D82-38FE-ABEC-0D575450C73B> /usr/lib/libxslt.1.dylib
0x624b000 - 0x628dfff libGLU.dylib (9.6) <6A7E248D-3936-3B0D-9BF2-E4F0D2FE5306> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x629b000 - 0x62a3ffe libGFXShared.dylib (9.6) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x62aa000 - 0x62b9fff libGL.dylib (9.6) <58C42A46-27D0-3228-B3C1-EC3923D49BAD> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x62cc000 - 0x62d0ffc com.apple.IOSurface (91 - 91) /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x62d8000 - 0x66d0fff com.apple.CoreGraphics (1.600.0 - 599.20.11) <82BA834B-C3D1-39CC-B9C3-5C4C976A3BCD> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x676b000 - 0x682eff1 com.apple.CoreText (352.0 - 367.19) <14FD889D-4D6D-3D53-B28E-2E23975B3C9D> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x6891000 - 0x699eff7 com.apple.ImageIO.framework (3.3.0 - 1042) <677F8044-E8B4-34A8-B7D9-575D7CEA019E> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x69f9000 - 0x6a6eff1 com.apple.ApplicationServices.ATS (360 - 363.3) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x6a96000 - 0x6b27fff com.apple.ColorSync (4.9.0 - 4.9.0) <8366AE10-0396-3100-B87A-A176E8ECE7B6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x6b66000 - 0x6bb5ff1 com.apple.HIServices (1.22 - 467.2) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x6be6000 - 0x6bf6ff5 com.apple.LangAnalysis (1.7.0 - 1.7.0) <71DE7754-0A47-3F35-B1BF-B1FE7E1311E0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x6c03000 - 0x6c9ffff com.apple.QD (3.50 - 298) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x6ccc000 - 0x6cd6ff7 com.apple.speech.synthesis.framework (4.7.1 - 4.7.1) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x6ce7000 - 0x6ddbfff libFontParser.dylib (111.1) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x6e34000 - 0x6e7aff7 libFontRegistry.dylib (127) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x6e9b000 - 0x6ebffff libJPEG.dylib (1042) /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x6ec7000 - 0x6f20ffa libTIFF.dylib (1042) <0EED8A3F-A7C6-3FE2-8F67-55813D5E543E> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x6f2e000 - 0x6f49ff6 libPng.dylib (1042) <1ADB59C7-343E-30CA-A8D2-93540C4A2E7D> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x6f51000 - 0x6f55ffa libGIF.dylib (1042) /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x6f5a000 - 0x7058fff libJP2.dylib (1042) <795B3209-2382-3F31-AEF7-588E4BCAAF06> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x707e000 - 0x7080ffb libRadiance.dylib (1042) <22E517A8-4725-3175-B5D1-5573FBE780B3> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7084000 - 0x70d0ff7 libcups.2.dylib (372.2) /usr/lib/libcups.2.dylib
0x70e2000 - 0x70fbfff com.apple.Kerberos (3.0 - 1) <91F17EB2-C70C-359C-B09D-96B52D2A9C9F> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7113000 - 0x7144ff5 com.apple.GSS (4.0 - 2.0) <8C72F861-47F5-3641-9744-B5EF9647C827> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x715f000 - 0x717cffb libresolv.9.dylib (54) <3EC12A7F-6BA1-3976-9F1F-6A4B76303028> /usr/lib/libresolv.9.dylib
0x7187000 - 0x7277ffb libiconv.2.dylib (41) <848FEBA7-2E3E-3ECB-BD59-007F32468787> /usr/lib/libiconv.2.dylib
0x7285000 - 0x72f0ff9 com.apple.Heimdal (4.0 - 2.0) /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7315000 - 0x7316ffc com.apple.TrustEvaluationAgent (2.0 - 25) <064B485D-56E0-3DD7-BBE2-E08A5BFFF8B3> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x731b000 - 0x731ffff libheimdal-asn1.dylib (323.15) <2C5FF5E6-F253-387E-959A-B1926DD99B31> /usr/lib/libheimdal-asn1.dylib
0x7325000 - 0x7331ff7 com.apple.OpenDirectory (10.9 - 173.90.1) /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7341000 - 0x734affa com.apple.CommonAuth (4.0 - 2.0) <7E72F700-6072-3822-8AAF-F14D456F7E7D> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7351000 - 0x73c7ff3 com.apple.securityfoundation (6.0 - 55122.1) <18024F59-DE2B-3FC5-A29F-8F2B27349685> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x73f8000 - 0x7435ffb libGLImage.dylib (9.6) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x743d000 - 0x743fffe libCVMSPluginSupport.dylib (9.6) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7444000 - 0x7448ffe libCoreVMClient.dylib (58.1) <0EB8FFD7-AFED-3A63-810E-29629831D43D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x744e000 - 0x7457fff com.apple.audio.SoundManager (4.1 - 4.1) <68B7CEB7-AF09-3E24-8548-6ABF065B5186> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x7460000 - 0x7464fff com.apple.CommonPanels (1.2.6 - 96) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x746c000 - 0x746fff7 com.apple.help (1.3.3 - 46) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7475000 - 0x77eaff9 com.apple.HIToolbox (2.1 - 697.4) <8CB677B7-43FC-3534-A685-5A5445C95F7D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7950000 - 0x79a3fff com.apple.htmlrendering (77 - 1.1.4) <408FA30F-4FE9-3162-9FFD-677E8569C1EA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x79ca000 - 0x79ddfff com.apple.ImageCapture (9.0 - 9.0) <63D5C96F-1893-3F35-ADFB-EE451AFD87E6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x79f6000 - 0x7a8dff7 com.apple.ink.framework (10.9 - 207) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7ab7000 - 0x7af5ff7 com.apple.NavigationServices (3.8 - 215) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x7b1c000 - 0x7b37ff5 com.apple.openscripting (1.4 - 157) <5C161A52-8D2F-3D56-A988-05727BED7A59> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7b49000 - 0x7b4bfff com.apple.securityhi (9.0 - 55005) <4F6A2006-CC82-39D0-AA0F-C448CF3943AB> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7b50000 - 0x7b59fff com.apple.speech.recognition.framework (4.2.4 - 4.2.4) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7b62000 - 0x7c48ff7 com.apple.coreui (2.1 - 231) <1C1AE894-C5C2-3F1C-BF29-B152ECD9BD88> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7cd2000 - 0x7e09fff com.apple.desktopservices (1.8.2 - 1.8.2) /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7e7f000 - 0x7e93ff9 com.apple.MultitouchSupport.framework (245.13 - 245.13) <1576F96C-385B-3AAE-8A09-1D49091FE931> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7ea1000 - 0x7ebbff7 com.apple.GenerationalStorage (2.0 - 160.2) <8755F7F1-2402-387C-A32A-2270E7D680C8> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7ec9000 - 0x7f09ff7 com.apple.bom (14.0 - 193.1) /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x7f1b000 - 0x8210ff8 com.apple.CoreImage (9.2.7) /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x82b7000 - 0x830dff6 com.apple.ScalableUserInterface (1.0 - 1) <2C81641B-FA30-32FF-8B3E-3CB9BF53B2D9> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterface.framework/Versions/A/ScalableUserInterface
0x8326000 - 0x875aff7 com.apple.vision.FaceCore (3.0.0 - 3.0.0) <5B12F3E9-84F6-3183-B85D-FD19EF800ADB> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x896f000 - 0x897afff com.apple.CrashReporterSupport (10.9 - 538) <7ED18744-8296-3AB8-BBAA-77B0849CF88E> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x8987000 - 0x89d7fff com.apple.opencl (2.3.59 - 2.3.59) <4BEFE83C-1C89-3BB6-A445-9BE680C84FB3> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x89e9000 - 0x89f6ff7 com.apple.AppleFSCompression (56 - 1.0) <0C44B3E4-C4A7-3A65-9C1A-334CA3E35BDB> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x89fe000 - 0x8a1aff9 com.apple.Ubiquity (1.3 - 289) <1CEDC83D-7282-3B4D-8CF7-4FE045012391> /System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Ubiquity
0x8a2c000 - 0x8a3aff7 com.apple.Sharing (132.2 - 132.2) <87DBFC7A-9689-3B8E-AD16-5A9DFF9DE625> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x8a4a000 - 0x8a80fff com.apple.IconServices (25 - 25.17) /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x8aa8000 - 0x8ad3ff5 com.apple.ChunkingLibrary (2.0 - 155.1) <50BBBBF8-F30B-39EA-A512-11A47F429F2C> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x8adf000 - 0x8d48fff com.apple.AddressBook.framework (8.0 - 1369) /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
0x8eeb000 - 0x8f3cffb com.apple.CoreMedia (1.0 - 1273.49) <26F891C5-DF9F-3A2C-995A-827595F03CF2> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x8f66000 - 0x8fa2ff4 com.apple.RemoteViewServices (2.0 - 94) /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x8fcb000 - 0x9013fff com.apple.PerformanceAnalysis (1.47 - 47) /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x984e000 - 0x991cff7 com.apple.backup.framework (1.5.2 - 1.5.2) /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x998d000 - 0x9a16fff com.apple.CoreSymbolication (3.0 - 141) <4D580E6C-79B5-3583-9713-4DDF9A0D096C> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x9a2e000 - 0x9a8fff7 com.apple.Symbolication (1.4 - 129) <843C9ED1-A0BB-37F5-B445-579327C5D764> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x9abe000 - 0x9aecff3 com.apple.DebugSymbols (106 - 106) /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x9b05000 - 0xa072fff com.apple.QuartzComposer (5.1 - 319) <77419C8D-B822-3649-BBB4-2CF0F0993E9A> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0xa2db000 - 0xa379ff7 com.apple.PDFKit (2.9.1 - 2.9.1) <37D112C0-3AF4-399F-B1E0-09162CBA3741> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
0xa3c3000 - 0xa3e8ff7 com.apple.quartzfilters (1.8.0 - 1.7.0) /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
0xa406000 - 0xa685ff7 com.apple.imageKit (2.5 - 774) <53C3FA27-3830-3A15-9707-AF7369119866> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0xa829000 - 0xa903ff6 com.apple.QuickLookUIFramework (5.0 - 622.7) <6F9C5661-0D7D-3B54-AC34-55E1A24EC05A> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0xa97d000 - 0xaca3ffb com.apple.JavaScriptCore (9537 - 9537.74.4) <1AE99257-8FDA-3A6D-8463-D0BD07D77762> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0xad6e000 - 0xad71ff3 com.apple.AppleSystemInfo (3.0 - 3.0) <4586B503-A0A8-3654-AA48-D2F9FA0188CB> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
0xad77000 - 0xaea4ff9 com.apple.avfoundation (2.0 - 651.12) <5D46DA01-3CFB-375E-B134-8625EA3466A7> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
0xaf63000 - 0xb2d1fff com.apple.MediaToolbox (1.0 - 1273.49) <236C702F-BC87-3255-A8B3-C7B2C597DBCA> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0xb367000 - 0xb78cfe3 com.apple.VideoToolbox (1.0 - 1273.49) /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0xb7da000 - 0xb7f1ff4 com.apple.CoreMediaAuthoring (2.2 - 947) <1D8AD09F-B8E5-3958-89F4-8470D25AE9AE> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
0xb807000 - 0xb85aff3 com.apple.CoreMediaIO (407.0 - 4561) /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
0xb87e000 - 0xb897fff libAVFAudio.dylib (32.2) /System/Library/Frameworks/AVFoundation.framework/Versions/A/Resources/libAVFAudio.dylib
0xb8a7000 - 0xb9b7fed com.apple.MediaControlSender (2.0 - 200.34.4) <48A88743-4EB7-364B-968F-43C17FFCEB97> /System/Library/PrivateFrameworks/MediaControlSender.framework/Versions/A/MediaControlSender
0xb9ea000 - 0xba1cffb com.apple.CoreAVCHD (5.7.0 - 5700.4.3) <30CF0E7B-3511-318F-AC31-06C29EDC111E> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0xba26000 - 0xba2bfff com.apple.MediaAccessibility (1.0 - 43) <1CC2B661-146A-3FF3-B843-508F611F7B4B> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0xba36000 - 0xbeddfe7 com.apple.CoreAUC (6.22.08 - 6.22.08) <3F9E2986-8FF9-3339-A0C8-DC1186C4A5EC> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0xbeeb000 - 0xbf0aff9 com.apple.framework.Apple80211 (9.3.1 - 931.58) <120A58B6-9DC7-3001-9735-C08661A3ECC0> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0xbf15000 - 0xbf1efff com.apple.AppleSRP (5.0 - 1) <6B946F4B-7DC4-3E82-BF2C-BE0930E3CF47> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0xbf25000 - 0xbf8bffb com.apple.CoreUtils (2.0 - 200.34.4) /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0xbfb2000 - 0xc019ffc com.apple.framework.CoreWLAN (4.3.2 - 432.47) /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0xc048000 - 0xc073ff7 libpcap.A.dylib (42) <66FBEAD3-FE91-3A89-8706-FB95229068AC> /usr/lib/libpcap.A.dylib
0xc07f000 - 0xc0e9ff7 com.apple.framework.CoreWiFi (2.0 - 200.21.1) <13EE6C12-B981-3132-864A-D493B91AE37E> /System/Library/Frameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0xc127000 - 0xc17bfff com.apple.AppleVAFramework (5.0.27 - 5.0.27) <95A1E1CF-FC3E-3203-8683-34823CD70B6B> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0xc185000 - 0xc18cff7 com.apple.XPCService (2.0 - 1) <94783930-9E46-394F-B1B2-9CA57CBA2D25> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
0xc195000 - 0xc19fff2 com.apple.AppSandbox (3.0 - 1) /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
0xc1a8000 - 0xc1d2ff7 libsandbox.1.dylib (278.11) /usr/lib/libsandbox.1.dylib
0xc1d9000 - 0xc1eeff3 com.apple.AppContainer (3.0 - 1) <017FED4F-AD6E-3A56-806B-A2D33E69EFF9> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
0xc1fe000 - 0xc200fff com.apple.SecCodeWrapper (3.0 - 1) <066E1E30-2EEA-3166-8F86-D1054B50875B> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
0xc207000 - 0xc20efff libMatch.1.dylib (19) <3B3680FC-2AC9-37CC-B262-5ACE2CF8939A> /usr/lib/libMatch.1.dylib
0xc213000 - 0xc298ffc com.apple.CorePDF (4.0 - 4) <73557F2A-B0EF-3128-90FE-8EDD7824CE73> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
0xc2d8000 - 0xc32dff7 com.apple.QuickLookFramework (5.0 - 622.7) <215A2C74-801A-39AE-85E4-A1E5031CFD38> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0xc35f000 - 0xc369ff3 com.apple.DisplayServicesFW (2.8 - 360.8.14) /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0xc373000 - 0xc3c8ff3 com.apple.ImageCaptureCore (5.0 - 5.0) <69A007AE-4654-3C79-9AF6-5EC8F173F225> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0xc3f4000 - 0xc40aff9 com.apple.aps.framework (4.0 - 4.0) /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
0xc41f000 - 0xc420fff com.apple.AddressBook.ContactsData (8.0 - 1369) /System/Library/PrivateFrameworks/ContactsData.framework/Versions/A/ContactsData
0xc426000 - 0xc42cff7 com.apple.AddressBook.ContactsFoundation (8.0 - 1369) <9A9AB323-5534-3FD5-879C-763E4265AED1> /System/Library/PrivateFrameworks/ContactsFoundation.framework/Versions/A/ContactsFoundation
0xc436000 - 0xc440ff7 com.apple.DirectoryService.Framework (10.9 - 173.90.1) <6CD2D996-2972-30A3-B4AD-BB1B816EFDCC> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0xc449000 - 0xc47aff4 com.apple.securityinterface (9.0 - 55047) <0D5ED2B8-C973-3C91-BA45-22501A043263> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
0xc499000 - 0xc4a0ff1 com.apple.phonenumbers (1.1.1 - 105) <4279F426-BD5E-3716-A23E-5A718B01F466> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
0xc4a7000 - 0xc4fcff7 com.apple.framework.internetaccounts (2.1 - 210) <3E555C08-C8FA-3175-8C3F-E49F6F5238A6> /System/Library/PrivateFrameworks/InternetAccounts.framework/Versions/A/InternetAccounts
0xc52f000 - 0xc567fff com.apple.LDAPFramework (2.4.28 - 194.5) <4399D209-B119-3ACC-97AF-F2E14DD207CB> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0xc574000 - 0xc5a3ff1 com.apple.frameworks.CoreDaemon (1.3 - 1.3) <2215559E-C517-3122-906F-156FD3CC10AD> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
0xc5b1000 - 0xc694ff7 libcrypto.0.9.8.dylib (50) /usr/lib/libcrypto.0.9.8.dylib
0xc6e7000 - 0xc7feffb com.apple.WebKit (9537 - 9537.74.9) <27AE437D-1DBE-34E9-8FE5-E9A5BD5CEBB0> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0xc8b3000 - 0xc95eff5 com.apple.imcore (10.0 - 1000) <000D6E8B-1067-3FE1-8524-18A8710C572E> /System/Library/PrivateFrameworks/IMCore.framework/Versions/A/IMCore
0xc98a000 - 0xc9a8ff5 com.apple.frameworks.preferencepanes (16.0 - 16.0) <3E3368EE-CAD3-3096-89BC-D006A25A6294> /System/Library/Frameworks/PreferencePanes.framework/Versions/A/PreferencePanes
0xc9c0000 - 0xccc1ff1 com.apple.AOSKit (1.06 - 176) /System/Library/PrivateFrameworks/AOSKit.framework/Versions/A/AOSKit
0xcce2000 - 0xdb7dff3 com.apple.WebCore (9537 - 9537.74.11) <2D24AE4B-EE47-3DC2-82A1-9EEBD89E2140> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0xe3a1000 - 0xe403ff3 com.apple.imfoundation (10.0 - 1000) <20565092-0897-3E34-A35A-E1F027D53A26> /System/Library/PrivateFrameworks/IMFoundation.framework/Versions/A/IMFoundation
0xe434000 - 0xe435fff com.apple.marco (10.0 - 1000) /System/Library/PrivateFrameworks/Marco.framework/Versions/A/Marco
0xe43c000 - 0xe45cfff com.apple.facetimeservices (10.0 - 1000) /System/Library/PrivateFrameworks/FTServices.framework/Versions/A/FTServices
0xe46a000 - 0xe4a9ff5 com.apple.ids (10.0 - 1000) /System/Library/PrivateFrameworks/IDS.framework/Versions/A/IDS
0xe4be000 - 0xe4eeff3 libtidy.A.dylib (15.12) <3DBE95FE-8FA7-3584-9202-E37B54B3B064> /usr/lib/libtidy.A.dylib
0xe4fb000 - 0xe4fcff7 com.apple.diagnosticlogcollection (10.0 - 1000) /System/Library/PrivateFrameworks/DiagnosticLogCollection.framework/Versions/A/DiagnosticLogCollection
0xe503000 - 0xe516ff7 com.apple.idsfoundation (10.0 - 1000) <67D0D240-D471-3882-8FAA-922FD91C3846> /System/Library/PrivateFrameworks/IDSFoundation.framework/Versions/A/IDSFoundation
0xe524000 - 0xe582fff com.apple.ViewBridge (1.0 - 46.2) <64AC1689-5F60-3E16-AE62-A2259E0D57EC> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0xe5ad000 - 0xe5adffe com.apple.AOSMigrate (1.0 - 1) /System/Library/PrivateFrameworks/AOSMigrate.framework/Versions/A/AOSMigrate
0xe5b1000 - 0xe617ff4 com.apple.ISSupport (1.9.9 - 57) /System/Library/PrivateFrameworks/ISSupport.framework/Versions/A/ISSupport
0xe64e000 - 0xe65eff7 libsasl2.2.dylib (170) /usr/lib/libsasl2.2.dylib
0xe665000 - 0xe69affd libssl.0.9.8.dylib (50) /usr/lib/libssl.0.9.8.dylib
0xe6ad000 - 0xe774ff7 com.apple.DiscRecording (8.0 - 8000.4.6) <84A7EC09-3BBD-3E04-A88C-6D3B724448FF> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0xe7cc000 - 0xe7d7fff libcsfde.dylib (380) <06651EEB-0EF8-390F-B3F4-4BE2D82D7BB8> /usr/lib/libcsfde.dylib
0xe7e1000 - 0xe827ff7 libcurl.4.dylib (78.90.1) /usr/lib/libcurl.4.dylib
0xe836000 - 0xe86eff7 com.apple.MediaKit (15 - 709) <82E0F8C0-313C-379C-9994-4D21587D0C0C> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0xe87e000 - 0xe91dff7 libCoreStorage.dylib (380) <9FEEDD0F-5CDC-3BCA-
gabe miller
Re: "Final Cut Pro quit unexpectedly while using Final Cut Pro plug-in"
on Sep 28, 2014 at 4:15:21 am
While I didn't solve the problem I did find a work around. I took the media offline and opened the project, luckily it didn't crash. From there I isolated sequences, folders, etc., until I was able to find the ones causing FCP to crash. In this case, it was a feature project on the 18th cut, so there were lots of sequences (1-18 and then some), deleting all but the essential sequences seems to have fixed the problem.
These are the steps I took:
1) make all the media offline (eject the drives)
2) duplicate the project and open the copy (this way nothing get's screwed up on your original project)
3) delete all unnecessary sequences, save, and close FCP
4) re-mount drives and open the project (copied version); for me, this stopped the crashes
5) if it still crashes, take the project offline again
6) make a third copy of the original project to use as a master with all the original data in it (there's no longer any need for the copy made in step 2)
7) open the master (copied version) and a new FCP project
8) to make sure it's going to work, start off by just copying your most important sequence into the new project and save it
9) close FCP and re-mount the drives
10) open the new FCP project that only contains that important sequence, if it doesn't crash, we're on the right path, if it crashes, unfortunately, I don't know how to help
11) repeat this process, taking broad strokes copying everything to the new project except folders/files that you suspect might be causing the problem; it might take some whittling down and repeating the process to find the corrupt sequence(s), media, etc.
Michael Williams
on Sep 22, 2015 at 7:13:21 pm
You just saved me. I was pulling my hair out with the same issue.
thanks!
Mike
Michael V. Williams
producer/editor
http://www.vernonvision.com
