Default transition weirdness
Greg Ball
on Sep 26, 2014 at 2:34:05 pm
I'm editing on FCP 7.03. I'm trying to change the default transition Cross Dissolve from 1:00 to :20.
I clear the default, then change the length to :20 and set it as the new default. For some reason when I choose that setting in my timeline the dissolve length is :48!
I've never had this happen before. Any suggestions? Thanks so much.
Mark Suszko
Re: Default transition weirdness
on Sep 26, 2014 at 2:44:19 pm
What happens when you select the transition on the timeline, shift+right click, and change your properties there?
Greg Ball
on Sep 26, 2014 at 5:00:26 pm
Hi Mark,
When I do that it shows ;48 frames. Of course i can change it there, but that defeats the purpose, since I have lots of cross dissolves (all at 20 frames) I need to make.
Dave LaRonde
on Sep 26, 2014 at 3:58:28 pm
What's the frame rate of the footage and the timeline?
Dave LaRonde
Promotion Producer
Greg Ball
on Sep 26, 2014 at 4:57:04 pm
Hi Dave. The frame rate for the footage and Timeline are both 59.94
Dave LaRonde
on Sep 26, 2014 at 5:50:56 pm
You've performed the litany of standard remedies for FCP Weirdness, correct?
Delete render files with the Render Manager, trash preferences, repair permissions, run Disk Warrior....
Dave LaRonde
Promotion Producer
Greg Ball
on Sep 26, 2014 at 7:59:07 pm
Actually Dave - trashing preferences sorta worked. However I needed to set the cross dissolve default to 10 frames instead of 20, so it would work on the 59.94 timeline. Does that make sense?
Dave LaRonde
on Oct 3, 2014 at 5:41:12 pm
No. It should work. How long are the trim handles on your clips? If you have only 10 frames trimmed off the in point of a clip, you can only do a 10-frame dissolve.
Dave LaRonde
Promotion Producer
