converting wmv to mov in OS 10.6.8
david mayer
on Sep 25, 2014 at 10:04:42 pm
I am running FC 7 with OS 10.6.8
Works great
But I need Flip4Mac or something else to convert .wmv movies for Final Cut.
Flip4Mac requires OS 10.7
Don't want to upgrade and have FCP not work in 10.7.
Suggestions for converting .wmv movies?
(I have tried Compressor, MPEG Streamclip and ClipWrap.)
Dave
iMac 2.8 GHz Intel Core i7, 8 GB
OS 10.6.8
Final Cut Pro 7.0.3
Canon C100
Shane Ross
Re: converting wmv to mov in OS 10.6.8
on Sep 25, 2014 at 11:27:02 pm
FCP 7 works under 10.7 and 10.8. No issues.
Biggest issue will be finding them to install...
Shane
Little Frog Post
david mayer
on Sep 26, 2014 at 11:26:33 am
you mean i need to find disks?
OS 10.6.8
Final Cut Pro 7.0.3
Canon C100
Shane Ross
on Sep 26, 2014 at 1:41:26 pm
10.7 was a disc. 10.8 was the first download only. But I don't think they sell it anymore. For 10.7...you might need to see if someone you know has that, or look on eBay
Shane
Little Frog Post
lopez parri
on Oct 4, 2014 at 4:22:37 am
Go and get AppGeeker converter, it works well in converting between videos including .wmv file.
It's quite simplistic in design but I normally just set it to iPad Air and let it do it's thing.
James Emily
on Apr 9, 2015 at 7:09:10 am
To import WMV to FCP, we had better convert WMV to FCP more supported Apple ProRes MOV. iDealshare VideoGo is just the right one which can convert WMV to MOV(Apple ProRes) or MOV(QuickTime) on Mac OS X.
Step by step guide at http://www.idealshare.net/video-converter/wmv-to-mov-converter-mac-windows....
It also can convert AVI, MKV, ASF, FLV, VOB, 3GP, AVCHD, MXF, MTS and etc to Final Cut Pro supported Apple ProRes MOV
chris king
on Oct 21, 2016 at 5:39:00 am
Well, you can't edit a WMV video in Final Cut Pro directly even you upgraded to FCP X. To solve the issue, you need to change the file extentsion from ".wmv" to a codec that FCP can read more easily (without rendering basically). The codec is Apple ProRes, which ensures maximum editing quality and efficiency when working with Final Cut Pro.
