XML import errors (non-critical). What do they mean?
Karel Voners
on Sep 20, 2014 at 10:19:58 am
I'm trying to rebuild a project because it is behaving funny. When I export-import via xml the issues are resolved but I do get some non-critical errors.
Does anyone know what they mean? Its a 3 hour cut so I can't risk anything to shift or move because it will be impossible to spot and I can't take the risk noticing something is off 2 weeks down the lineā€¦
Any help greatly appreciated!
Sat, Sep 20, 2014, 12:07 PM - Errors Found Importing SW - PART 1.xml
<file>: Required element <timebase> has a value that is out of range. Resulting <file> definition may not behave correcctly.( line 65535 )
sequence item: Required element <timebase> has a value that is out of range. Resulting sequence item definition may not behave correcctly.( line 65535 )
Sat, Sep 20, 2014, 12:11 PM - Errors Found Importing SW - PART 2.xml
<sequence>: Unable to edit <clipitem> "02 Shower-AIFF 48k16bit.aiff" into <sequence> " SW - PART 2".( line 65535 )
<sequence>: Unable to edit <transitionitem> "" into <sequence> SW - PART 2".( line 4 )
<clipitem>: Unable to get audio <clipitem> for <effect> "audiolevels".( line 65535 )
<clipitem>: Unable to get audio <clipitem> for <effect> "audiopan".( line 65535 )
<clipitem>: Unable to get video <clipitem> for <effect> "video".( line 65535 )
<link>: <linkclipref> and other <link> data mismatched. Data defined in <linkclipref> element will be used.( line 65535 )
Sat, Sep 20, 2014, 12:17 PM - Errors Found Importing SW - PART 3.xml
<sequence>: Unable to edit <clipitem> "THE WORLD AT WAR_V3_DV-pal" into <sequence> " SW - PART 3".( line 65535 )
<sequence>: Unable to edit <clipitem> "THE WORLD AT WAR_V3_DV-pal" into <sequence> "china drones".( line 65535 )
<sequence>: Unable to edit <transitionitem> "" into <sequence> china drones".( line 65535 )
<sequence>: Unable to edit <clipitem> "02 Shower-AIFF 48k16bit.aiff" into <sequence> " SW - PART 3".( line 65535 )
<sequence>: Unable to edit <transitionitem> "" into <sequence> SW - PART 3".( line 4 )
