Does Audio Recorded with FCP 7 meet these format requirements
Jared Smith
on Sep 11, 2014 at 10:06:11 pm
I did a super simple audio recording for my boss using FCP 7
It is an audio recording that will be used for clients as they wait "on hold"
It was a simple lav going into a camera... then I just did away with the video
So the phone company has given me the format requirements for it to play correctly on our phone system and I need to know if anyone here can tell me if FCP will meet these requirements as is- and if not, what is the process to get it right
thanks
jared
7977_screenshot20140911at5.04.54pm.png.zip
Dave LaRonde
Re: Does Audio Recorded with FCP 7 meet these format requirements
on Sep 12, 2014 at 12:27:25 am
I don't know if FCP can do it, but Compressor ought to do the trick. FCP isn't really built to export crummy phone-quality audio. You can still cut & export in FCP to convert in Compressor.
Dave LaRonde
Promotion Producer
John Fishback
on Sep 12, 2014 at 9:49:39 pm
Audacity can do this. I found these instructions a while back in this thread.
1. Open Audacity.
2. Open the mono Wav file.
3. Click on the bottom left corner Project Rate icon to change the sample rate to 8000.
4. Go File-Preferences and click on File Formats. Under Uncompressed Export Format, choose other.
5. Choose WAV (Microsoft) for the Header and U-Law for Encoding. Hit OK.
6. Now just select the audio file and use File-"Export As WAV" Choose the location and save.
Once I did all of this, the phone messaging system accepted the file.
John
MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.9.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCP-X 10.1.3, Motion 5.0.7, Compressor 4.0.7
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
