DV capture to Final Cut Pro 7 on MacBook Pro impossible
Nhan Nguyen Dinh
on Sep 10, 2014 at 9:48:37 pm
MacBook Pro OS 10.6.8
FCP 7
Hello, please help me :
1/
I connect my MacBook Pro OS 10.6.8 to DSR 11, cassettte Mini DV, then I click List and Capture, there is a message telling me that NO Video Tape Reader have been connected to my MacBook Pro.(Mys DSR 11 is connected !!!)
I Quit FCP
I trash Preferences wit Preference Manger :
I open FCP
NO EFFECT, the same as previousy.
2/
I quit FCP again
I disconnect DSR 11 and replace by the camera HVX 200, with MiniDV play back.
Please help
Thanks very much
Nhan
Shane Ross
Re: DV capture to Final Cut Pro 7 on MacBook Pro impossible
on Sep 10, 2014 at 11:29:20 pm
Are you using a DV/NTSC Easy setup? Or DV/PAL?
Shane
Little Frog Post
Roger Poole
on Sep 10, 2014 at 11:56:43 pm
FCP grabs the firewire ports when it launches, it doesn't like it if you connect a firewire device whilst FCP is running. Try connecting the DSR 11, switch it on and then launch FCP. It should then see the deck or camera when you go to log and capture.
From the Apple menu go to "about this Mac" >More info
Go to Firewire.
Any connected firewire devices should be listed, if not then you have a faulty cable or Firewire port.
Nhan Nguyen Dinh
on Sep 11, 2014 at 12:55:30 am
Hi Roger
I'll do what you advised me and will write you to-morrow, it's 3 o'clock in the morning in Paris
Thank you very much
Nhan
Nhan Nguyen Dinh
on Sep 11, 2014 at 1:45:03 pm
Hi Roger
I followed your advise : It works : Thank you very much
Nhân
Nhan Nguyen Dinh
on Sep 11, 2014 at 12:59:58 am
Hi
Thank your for your response :
It was DV/PAL
Waiting for your solution
Best regards
Nhan
Nhan Nguyen Dinh
on Sep 11, 2014 at 1:46:30 pm
Hi
I have checked, it is DV/PAL
Best regards
Nhan
