H264 Bitrate Limit
Andrei Popa
H264 Bitrate Limit
on Sep 8, 2014 at 11:23:23 pm
Hi there,
I have a 720P video that I have to encode in h264 with a bitrate of 12Mbps.
Is this possible?
The max I can get either in Media Encoder or Final Cut (quality settings maxed out) is 5Mbps in MOV format at 10Mbps in MP4 format.
If this is not the limit, how can i get a bitrate of 12Mbps with the H264 codec for a 720P video
Dave LaRonde
Re: H264 Bitrate Limit
on Sep 9, 2014 at 12:44:11 am
Custom presets.
Dave LaRonde
Promotion Producer
Andrei Popa
on Sep 9, 2014 at 9:20:52 am
Sure custom presets, but what I'm talking about is bitrate.
And I can't get those bitrates even with the settings maxed out...
Christopher McDonell
on Sep 15, 2014 at 6:10:01 am
Do you have Apple Compressor? I think you can go up to 30,000 Kbps.
Andrei Popa
on Sep 16, 2014 at 6:38:24 pm
Hi Christopher,
Yes I do, but for some reason I noticed there is something very weird going on on my computer.
No matter if I use Adobe Media Encoder or Compressor, and I select these high bitrate settings, my computer ignores them and makes a file that is usually 3 to 5mbps...
on Sep 16, 2014 at 6:53:02 pm
I think I know your problem. In Compressor, you have to duplicate the setting first. Your copy will then appear under the CUSTOM tab. That's the setting you can change and customize to your heart's desire. Make sure that's the setting you're applying to your file. The other settings are not customizable in the same way they were in Compressor 3 (I don't know about 4).
Andrei Popa
on Sep 16, 2014 at 6:57:08 pm
The way I did it, is start a custom setting from scratch.
It should work that way too right? Shouldn't have to duplicate it...
on Sep 16, 2014 at 7:09:25 pm
I've just duplicated, changed the title and customized. But if you can create a custom setting from scratch, I'm sure that will work. I was guessing that your problem was dragging in one of Apple's presets, and thinking you were changing the settings when nothing was saving. Hope it works for you!
