FCP 7 - Frame Rate Conversioin Issue
Matt Tente
on Sep 2, 2014 at 3:53:08 am
I have a 20 minute project shot 1920x1080 and 23.98 (H264). I converted the file to ProRes to be edited in FCP7. The intended delivery copy is 1920x1080 and 23.98.
For some reason, the editor set the sequences to 1280x720 and 29.97...
Is there a quick and efficient way to update/change the settings beyond rebuilding the entire sequence from scratch?
I know copying and pasting in a new sequence with the correct settings diminishes the quality and leaves gaps.
Shane Ross
Re: FCP 7 - Frame Rate Conversioin Issue
on Sep 2, 2014 at 4:42:51 am
[Matt Tente] "Is there a quick and efficient way to update/change the settings beyond rebuilding the entire sequence from scratch?"
Nope... Well, sorta. You won't have to redo from scratch, but you will have a LOT of fixing to do.
1) create a new sequence.
2) Drop a clip you converted into that sequence. Click yes when FCP asks if you want to change the sequence settings to match.
3) delete the clip. The task was to get a sequence with the proper settings.
4) Select ALL and COPY all the clips from the bad sequence.
5) Paste into the new sequence.
6) Fix all the gaps and potential sync issues.
7) Slap the editor.
[Matt Tente] "I know copying and pasting in a new sequence with the correct settings diminishes the quality and leaves gaps."
Yeah, but you didn't know to slap the editor...
Shane
Little Frog Post
Matt Tente
on Sep 2, 2014 at 4:59:29 am
Thanks.
Are there any other issues glitches/issues I should expect or anticipate from this process beyond the gaps?
Shane Ross
on Sep 2, 2014 at 6:30:10 am
Possible sync slippage
Shane
Little Frog Post
