How to export a Quicktime file with 5.1 audio?
Joe Riggs
on Sep 1, 2014 at 7:39:27 am
I'm pretty naive when it comes to 5.1, I've been given a 5.1 mix broken down into 6 channels (L,C,R,Ls, etc..) with the task of combining it for a 5.1 mix to attach to the final pro res .mov file.
1. First is it possible to create a digital Pro Res file, with 5.1 audio, that will play back 5.1 via quicktime or VLC, or is 5.1 strictly done when creating a DVD/blu ray ?
2. Is there any way to end up with a 5.1 audio and Pro res video within FInal Cut or must it be run through compressor to create the 5.1?
Shane Ross
Re: How to export a Quicktime file with 5.1 audio?
on Sep 1, 2014 at 5:23:15 pm
Watch this tutorial....
http://library.creativecow.net/ross_shane/multi-audio/1
And note that one of the items in the dropdown menu in the audio area is for 5.1 audio.
Shane
Little Frog Post
